Question about Coldtech J1GR-05S Commercial Beverage Dispenser
Where do i get (3) replacement bulbs for my J1GR-05S?
Hoe do I a manual for a coldtech J1GR-15S
Google (coldtech)(J1GR-15S)(manual) without parens.
Jul 09, 2018 | Coldtech Refrigerators
How do I use smarteks mini cord-cordless machine with pedal and adapter. RX-05S
well the manual should tell you but if the picture shown is it looks really simple to figure out
Jan 30, 2015 | Rex Smartek RX-05
What type of ballast is in a Coldtech j1gr-24l
the number of lamps and the size/ wattage of the lamps. it would really help to take the old one in with you.
Mar 08, 2013 | Coldtech J1GR-24L Beverage Cooler
My refrigerator does not cool enought and leaks at the back because the pipes next to the compressor are frozen
You must have a freon leak somewhere. Because from the indications you gave it sounds like you are low on freon.
Aug 13, 2011 | Coldtech J1GR-05S Commercial Beverage...
We have a Coldtech Beverage Cooler that doesn't seem to be keeping the drinks as cold as it did? Possible problem?
Dirty condenser coils will compromise cooling. Do a good hoovering around the coils and make sure the condenser fan motor air flow is not restricted.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 28, 2010 | Coldtech J1GR-24L Beverage Cooler
I have a f-350 2004, just quit at a red light,,, no warning. replaced cam sensor, nothing,,replaced crank sensor,,nothing. what next
Do you have headlights? I am not familiar with 05s but again you might want to go to auto parts stores or wally world and buy a code reader. If you have everything it could be anything from a fuseable link, to ignition system failure as in (coil) (fuse) etc. Again it is a problem hard to diagnose without actually inspecting it. Buy a code reader. It might not help your problem but it wont hurt to have it
Apr 05, 2010 | 2005 Ford F 350 Super Duty
Where are my fuel filters located on a 2006 subaru legacy 2.5 non turbo
Hello SUBY bro, we've got an 05 Legacy 2.5i
Here is your answer which I'm quoting from LEGACYGT.COM: " The fuel filter in the 05s is in the fuel tank and there is no scheduled replacement interval." The same should be for your 06 model
Here is the we address of the forum: http://www.legacygt.com/forums/showthread.php?t=16365
Oct 11, 2009 | 2006 Subaru Legacy
How do I get the flouresent light tube out to repace it?
Pull on the end of the fixture (receptical). The fixture is made so that the receiving end of the recepticals slide off and on. Make sure your pulling on the receptical part and not from the bulb or cover. Just pull (mine seemed to have one end looser than the other, I pulled on the looser end) and it slides off. After your one end is off, lift the bulb and plastic tube cover out and replace as needed.
Apr 26, 2009 | Coldtech J1GR-24L Beverage Cooler
Fagor dish washer VFU-05S
What do I do to overcome the fault 'F3' accompanied by beeping ?
Jul 15, 2008 | Fagor LFA-019 SS Stainless Steel...
Coldtech J1GR-05S Commercial Beverage Dispenser Logo
91 people viewed this question
Top Coldtech Refrigerators Experts
billconfused
Randy Justice
ray gallant
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
