Question about Logitech LOG9804401403 Quickcall USB Speakerphone with One-Touch Call Pickup/Answer
Hello! I've recently bought the logitech Quickcall USB speakerphone to my computer and the microphone wont work. I've followed the installation and re-installed it and searched for updates. I've also tried to configure the microphone manually on the controlpanel, but without success. By all indications the microphone should be working. One notacible thing is that the name when selecting the device manually says "speakerphone (disabled)" but i can still use the box for audio, it's just the mic that wont work. I'm currently running the audio in my headset through an audiocard on a windows 7 computer. Please help, im out of ideas!
  • 5 Answers
SOURCE: Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
Posted on Nov 10, 2007
SOURCE: QuickCam mic doesn't work
For XP users,try:
>Sounds and Audio Devices
>Sound Playback
Click on drop down menu arrow.
If there are two audio devices listed: Deselect current device; select second device.
Posted on Dec 10, 2007
SOURCE: Headset Doesn't Work...
Same problem for me, except the headphones wont work with team speak or playing back voice from the sound recorder, I just get a low frequency quiet and very muffled and distoreted sound, Mic works fine with speakers though. :(
Posted on Dec 17, 2007
SOURCE: logitech microphone is not working
no sound
Posted on Oct 17, 2008
  • 14 Answers
SOURCE: Logitech cordless internet handset for skype -- base unit problem
You can uninstall the Skype Application and reinstall it in compatiblity mode and chose XP. To do this right click on the install exe and go to the compatibility tab/section and from the drop down chose XP. Then try reinstalling it.
That has solved a lot of issue for me with Vista.
Let me know if you need anymore help or if that does not solve your issue.
Posted on Jan 28, 2009
Logitech mic 600 wont work computer dont even show its plugged in
Manually install it or if you have a disk with it load that and choose where its hooked up at or try another plug in if its usb capable. Your mic jack might be messed up also if it doesn't plug into your usb. Plug and Play usually picks up on whatever you plug in. If all else fails press F2 before boot and under the BOOT tab make sure its plug and play accessible Press F10 and continue with bootup and see if works
Mar 02, 2011 | Logitech (980240-0403) Microphone
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
When I am on Skype my microphone works then doesn't work. It is a logitech webcam/microphone.
I found this problem on my computer.
I had connected the Logitech into a USB hub then connected the hub to the computer's USB port. Then saved the configuration in Skype didn't work, every time I opened Skype I had to configure the microphone and video setting in Skype again.
The FIX. connected the Logitech direct into the computer's USB port and configured the Skype - Logitech microphone and video save settings. No more problems
Feb 11, 2010 | ASUS M2N-E SLi Motherboard
When I plug in my Logitech USB Desktop Microphone into a usb port on my computer it does not detect the new software, how do I fix this so I can install it?
Sometimes you have to install the drivers and software before you plug the microphone in and sometimes it is the other way around.
Jan 20, 2010 | Logitech USB Desktop Consumer Microphone
Built in Microphone Logitech S5500
go to can either choose to work with build in mic or external.simply highlight input source and you are ready to go...
good luck
Jul 18, 2009 | Logitech Audio Players & Recorders
My logitech mouse wont move
You need to install the driver for your logitech mouse to work.
If your mouse is not recognized then follow the following steps,
To work around this issue, try one of the solutions below:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If that doesn't work, here is another option you can try:
Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps:
  • Click Start, and then click Run.
  • Type devmgmt.msc in the Open box, and then click OK.
  • Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
  • Right-click the USB Root Hub and then click Properties.
  • Click the Power Management tab.
  • Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
Jun 03, 2009 | Logitech Marble Mouse Trackball
Need a compatible software for logitech quick call usbspeaker phn
this speakerphone is not compatible with vista..if u do plz check ur logitech speaker phone with another comp
Thanks for using Fixya
Mar 16, 2009 | Logitech LOG9804401403 Quickcall USB...
My Logitech Microphone needs software.
try here,en?selectedcrid=408&selectedcid=221#
Sep 06, 2008 | Logitech USB Desktop Consumer Microphone
USB Logitech Microphone
the usb mocrophone doesnt require drivers on windows 2000.
it should work instantly after being pluged in.
Apr 11, 2008 | Logitech USB Desktop Consumer Microphone
For XP users,try:
>Sound Playback
Oct 05, 2007 | Logitech QuickCam Express Web Camera
Logitech LOG9804401403 Quickcall USB Speakerphone with One-Touch Call Pickup/Answer Logo
140 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
