Question about Golden Technologies Golden CompanioN II - 3 Wheel
I have a 3 wheel little rascal ser. # RF167552 or RO246254 (on rear) that will stop sometimes and you have to wait a little bit before it will go again. I have replaced the throttle pot #340034 and the speed pot #340038 and it still does it. The battery indicater always up like it is fully charged. Don't know what to do>
2 Suggested Answers
  • 103 Answers
SOURCE: sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
Posted on Mar 09, 2009
I have to push joystick back to go forward. An forward to go back. Much faster in reverse too
if you look under the seat and see that there are little black switches, one of them maybe broken. if there are no switches on the seat post. then your joystick thinks you are a front wheel drive instead of a rear wheel drive chair. Someone with a programmer can reverse this. get ahold of these people at this link I give you to find a technician close to you.1-800-257-7955 or Mobility Parts and Service Official Rascal Parts Supplier
or http://www.meritsusa.com/
May 02, 2016 | Rascal 318 Electric Scooter
Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
It is the same as a Rascal 600 only the 300 has smaller wheels.
The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
Scooter Doctor App
Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
Rascal Scooter model 245
If the throttle is stuck a little bit then it may not let you start it while the throttle is on
Apr 13, 2014 | Health & Beauty
97 mountaineer will not move in reverse
Could be the rear Emergency brakes are binding. Jack up the rear of the vehicle, put it in neutral and attempt to turn the rear wheels by hand.
You do not have to use the Emergency brakes to have problems with them. The linings fall off the metal shoe and bind up on the turning drum within the rear rotor. Then when the direction of rotation changes, the remaining brake linings regroup and jam the other way.
Sometimes the loose lining jams into small bits, pulverized, and sometimes form large chunks that jam the brakes.
Another potential problem you can check with the rear wheels off the ground and in neutral is the U-joints on the driveshaft. Popping is a symptom of play in the joints. Binding is a possibility but the joint is close to breaking at this point.
Apr 01, 2013 | 2003 Mercury Mountaineer
Snapper rear riding mower won't move while in gear
yes your looking at the problem easy to change close the vent on the fuel cap remove the battery and lift it up and stand it on the rear bumper tubes (thats what there there for) after replacing you might need to move the links for the cable up near the pedal
Jul 11, 2012 | Garden
I have an older Little Rascal and need a repair manual for it
Unfortunately the manuals are considered proprietary and not distributed, i've looked everywhere. What kind of controller do you have? I
Apr 25, 2012 | Electric Mobility 3 Wheel Motorized...
2001 rascal electric wheelchair booklet
Call customer service at 1-800-257-7955, the assure me that they will be able to assist you.
Dec 14, 2011 | Electric Mobility 4 Wheel Power Electric...
Right rear brake light/turn signal sometimes works, sometimes it doesn't. have tried replacing bulbs, the socket, still have same problem
Make sure the new socket is properly grounded. The black wire is the ground wire. Sometimes the wire[s] get loose at the turn signal switch connector. Remove the plastic shroud from the steering column directly under the steering wheel. The wire to be concerned with is orange with light blue tracer.This is the wire for the right rear turn & brake. It may be loose in the connector. Wiggle & gently pull on the wire. If it comes out of the connector, the little tang will need to be carefully pried out a little bit to make it lock when pushed back in place.
Feb 15, 2011 | 1999 Ford Expedition
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
Rca hidef tv
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
May 26, 2008 | RCA D52W19 52" Rear Projection Television
Golden Technologies Golden CompanioN II - 3 Wheel  Logo
51 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
