Question about Brother XL-2600I
Bobbin does not move like it should - Brother XL-2600I
  • sqs1011 Sep 10, 2010
    Can you give me more details please. What's it doing? Thanks.
    Genius:
  • 1,788 Answers
I think that you have it inserted or threaded wrong, read your manual more closely. If, you don't have one go to brother-usa.com and download one for free.
Posted on Sep 12, 2010
How to I wind a bobbin. The bobbin fits too tightly when I move it over to wind.
Make sure you are using the correct bobbin for your machine. Some bobbins are very similar to others but are not interchangeable.
Nov 01, 2015 | PfaFF Creative 7570
Singer 404 - The top needle thread will not pick up the bobbin thread on a Singer 404. I know the timing is fine, the needle is in correctly and I have loaded the bobbin thread correctly. I don't know...
is it the original bobbin? try a different bobbin, sometimes they won't work if slightly dent or chip! I know it sounds weird bt it's the truth about bobbins
Nov 14, 2013 | Sewing Machines
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
The bobbin is not moving
try checking to make sure the bobbin is inserted correctly into
the bobbin case
make sure the bobbin is not inserted into the bobbin case backwards
if the bobbin is not in backwards and the bobbin is inserted correctly
then the hook and hook race should be checked by a repair
shop to see if they are damaged
Nov 01, 2012 | Sewing Machines
The bobbin won't move, is there a certain way it should be placed in it's case
Yes, when you pull the bobbin thread out of the bobbin case, the bobbin should move/circle counter clockwise in the bobbin case. But also sometimes the bobbin may not be the perfect size for the bobbin case, take a good look! Or if your bobbin thread is too full in your bobbin this may cause won't move. In this case, take some of the thread out. Another thing is try to loosening the screw of the bobbin case. This need to be done in extra careful and slow. Since you don't really want to let the screw out of the bobbin case, because its a little bit delicate when it's happen. Hope it will work soon! Good Luck.
Aug 02, 2010 | Sewing Machines
I have a Singer Confidence 7469. It has only been
The bobbin case is not supposed to move. It should only have a little bit of wiggle room so there is enough clearence for the thread.
Feb 18, 2010 | Sewing Machines
Brother cs 6000 bobbin moves
Try this for me clean out the hook area under the bobbin case some times dust from thread and cloth build up under the bobbin case and it can push up the bobbin case and cause the same thing to happin.
Oct 18, 2009 | Brother CS-6000
Bobbin thread is pulling to the top, using embroidery needle, bobbin thread and proper thread on the top. As far as I know the machine is set right. This might not be the right place to ask, but am...
Setting bobbin case tension:
Put wound bobbin in bobbin case. Thread it in case. Hold the thread and carefully let go of the case only holding bobbin thread. The case should NOT move. Quickly let your hand drop 2-3 inches to let the bobbin case free fall for 2-3 inches, the bobbin case should move slightly then stop. It moves because it let’s a little thread off the bobbin. It should then stop .5"- 2" of thread should release. If so, your bobbin case tension is right. If it’s right then begin to look at your top thread tension. Always Always start with a properly adjusted bobbin case, then adjust your top tension accordingly.
Mar 18, 2009 | Bernina Artista 170
My zig zag stitch is distorted on the top side but looks perfect on the underside. I have tried adjusting the tensions and rethreaded the machine, etc.
The bobbin tension sounds too loose. This will help if you have a bobbin case and not a drop in bobbin. Let me know if you have a drop in bobbin:
Mar 12, 2009 | Sewing Machines
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Brother XL-2600I Logo
42 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
