Question about Clover Corporation C1704DVR
MAKES A TICKING NOISE AND LIGHTS ARE BLINKING IN THE FRONT, SOUNDS LIKE POWER SUPPLY TICKING. DO YOU KNOW WHAT PART IS CAUSING THE PROBLEM?
2 Suggested Answers
SOURCE: MODEL C1714DVR MAKES A TICKING
Hi, this is indeed a classic switchmode PSU fault, and is sometimes evidenced by faulty Capacitors, but they are NOT the Cause they are simply a result of the problem, IF indeed they are faulty at all. I see many people replacing capacitors willy, nilly, in the hope of effecting a repair. As you have discovered that is NOT the "Fix".
ALL problems have a "Cause" and any Damage done. BOTH MUST be found and fixed before the set can be truly considered fixed.
The PSU is responding to an Overload, somewhere in the set. Most likely, a component has failed, fully, or partially, and is causing the PSU, to "Trip" and try and restart.
You will most likely find it is a semiconductor, that's faulty.
You simply MUST obtain a service manual, to have any chance at all of effecting a repair, that lasts.
I have searched for one for you but have been unable to find one, so you need to go to the manufacturers website and contact them and request a service manual, link below.
http://www.cloverusa.com/.
Below is a link for your user manual, which may be of some assistance,
http://www.retrevo.com/support/Clover-C1714DVR-manual/id/21393bh245/t/2/
You see, just changing the capacitors well seldom permanently "Fix" anything for very long. You see, those "Blown Capacitors" were a "SYMPTOM" and are a "RESULT" of some other problem, seldom these days for capacitors fault, Unless, they are overheated. To spontaneously fail. The thing that "Kills" Capacitors, is AC Ripple/Voltage, and Over-voltage. So you see you MUST first find why those conditions exist before you can even begin to replace anything Capacitors included. So as ALWAYS the first place we start is at the Power Supply, now you make sure those voltages are correct. and if they aren't find out what not, and what is causing the problem. Then, in that way you can isolate the fault and fix the cause at the same time. That way it is "Fixed" and not symptomatically treated. Also it is nearly impossible to do anything without a service manual, you MUST try to get one of those, they will also help you identify exactly what is wrong and where to look and what to do.
OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
As a tip, check, the horizontal output transistor, see if the junction reads OK, these often fail and cause this exact symptoms, unfortunately so do about another 10 or so symptoms too....
Posted on Sep 11, 2010
Power supply has a ticking ticking blank screen no pix or sound
Sounds like a shorted H-out, likely due to a bad Flyback. That "chirping sound" is from the o0vercurrent protection in the power supply due to a short. Perhaps it is also a bad capacitor in the supply causing overvoltage shutdown too.
Apr 04, 2014 | Proscan 123882 Power Supply
Mr slim ticking noise
Open it and take a look, it could be debris or a loose wire.
Dec 06, 2013 | Mitsubishi Heating & Cooling
Truck wont start, interior lights flash
Check your battery terminals , are they clean and tight ? Next try to jump start your car. It may be that you have a bad battery.
Dec 05, 2013 | 2000 Mercury Mountaineer
I try to start the tv and all I hear is a slight squeeling noise, think it is the color wheel. I just bought a new lamp. the tv makes the noise it initially makes telling me it is trying to start but two...
If you hear a squeeling noise, then that would be your color wheel. When you replaced the lamp, did you reset the lamp hours? Did you check the power from ballast with a voltmeter to see if you are getting power to the lamp?
Feb 06, 2010 | Samsung Remote Control
Tv will not turn on, makes clicking noise as the green light blin
clicking = power supply not coming up
bad power supply, or bad (shorted) part causing power supply to not come up
with a volt meter we can troubleshoot
Feb 05, 2009 | Akai LCT2715 27 in. LCD Television
Knob Noise
You have a high frequency power supply close by. Most likely a track lighting system that is causing the clicking
Nov 13, 2007 | Jenn-Air JES8850 Electric Kitchen Range
Clover Corporation C1704DVR Logo
32 people viewed this question
Top Clover Corporation Televison & Video Experts
Are you a Clover Corporation Televison and Video Expert? Answer questions, earn points and help others
