Question about Garmin Nuvi 660 GPS Receiver
Touch screen inoperable nvii 660 full battery unit is on with either AC or DC power
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Sep 30, 2010
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
Dustbuster batteries won't hold a charge.
The AC is not full sine wave. The diode is in the wall adapter
Jan 15, 2013 | Computers & Internet
Device: Garmin Nuvi 660 NA. After power on, nuvi boots thru to the "Where to" page. On the prior page, the touchscreen will not click "Enter" but after a time delay, nuvi proceeds to...
*Master reset your Garmin Device:
1.Start with the unit OFF and unplugged from power;
2.Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
3.Continue touching and holding the lower right hand corner of the screen then power the unit ON
4.Release the power button when the device powers ON
5.You will see a new message: Do you really want to erase all user data?
6.Remove your finger from the touchscreen when this message displays - Touch Yes
7.The device will automatically reset. Please follow the on screen prompts on the nuvi .
*If the touchscreen is incorrectly detecting where your finger touches the screen, the screen may need to be calibrated.
1.Power the unit On.From the Where to? and View map screen, touch Settings . Touch Display>Touch Re-calibrate
2.A new screen will display that says Press Dot,Touch the Center of the Dot.
>Keep touching the center of the dot as it moves around the screen.
3.When Calibration Complete appears on the screen, please touch OK.
The screen will now be Re-calibrated.
*If the screen is not responding to touch, the device may not have enough power to function properly. Recharge the battery completely and try again. If the battery does not charge, it may need to be replaced.
If the screen is still not responding to touch commands or displaying properly, the display may need to be replaced. If sound comes from the device, it is likely the motherboard is working, and only the display needs to be replaced.
Refer to:Garmin Nuvi 660 Screen Replacement Guide
Before replacing the display, check that the ribbon cables connecting the display to the motherboard are connected securely.
Oct 04, 2011 | Garmin Nuvi 660 GPS Receiver
Memory full message
The unit may require a software update
goto http://www8.garmin.com/products/webupdater/
if that doesn't work you may need to do a master reset (you would loose any saved favorites and waypoints, saves etc)
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touchscreen when this message displays
  7. Touch Yes
  8. The device will automatically reset
(garmin.com/support/searchSupport)
Jun 13, 2011 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 660 touch screen is frozen. I've tried to reset it with the switch on the back. I've tried connecting it to my computer to reset it. Powering on and off don't work.
Sounds like your firmware needs updated. Just go to Garmin’s website then downloads and update your firmware. As long as there is no screen damage but just touch screen not working that will fix it. An easy test is to take out the battery and if the unit works for second then freezes you just need to update firmware. Turn off unit plug into computer via usb cable and do firmware update, that easy!!!! Hope that helps?
Aug 16, 2010 | Garmin Nuvi 660 GPS Receiver
The touch screen does not reacted when touched. The battery is fully charged and the software has been updated.
These units have a common problem with touchscreen failures. Please see this link for more info and how to have it repaired:
Jun 11, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 screen locked
I HAVE THE 205 UNIT MY LOCK IS ON THE POWER BUTTON SLIDE IT TO THE RIGHT IT LOCKS AND PUT IT IN CENTER TO UNLOCK - YOURS SHOULD BE CLOSE TO THAT - HOPE IT HELPS
May 09, 2010 | Garmin Nuvi 660 GPS Receiver
I have a rhodes 660, and it doesnt trun on. all u hear is a buzzing sound. does anyone know whats wrong.
This is LIKELY a power supply problem. The unit should have a label telling the power requirements. Match the polarity on DC units as well as the type AC od DC and voltage and current.
I suspect the input voltage from the supply is way lower than the required.
Apr 22, 2010 | Music
I received a Garmin Nuvi 255w as a gift back in October 2009. I am a Realtor and use this almost every day. Yesterday I was driving around, and I did have the Garmin charging with the car charger. In the...
The unit should still operate and turn on even with a dead battery when connected to an external power source such as the DC car charger, AC wall charger or USB cable (connected to a PC).
Please try the reset procedure listed here:
http://www.sharc.net/discus/messages/6/313.html?1269314749
- Jim
Mar 26, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
