Question about GE JASHO97985 Mouse
My gemini optical mouse model no . m409 is not working
Sometimes mouse just jams up wont work at all other times it work fine. I have put new batterys in did not works any better. I have model #1025 wireless optical mouse on XP. Did not get a CD to program it...
more detail on this as I don't know if it is current laser or if u are using past ball under mouse...if laser it may be the optical sensor may have a glitch...try using another mouse to see if that works...if it does then the problem is that mouse...because I can get any mouse I want and hook it up to my laptop and it works good...try it and see. Get a logi tech wireless mouse.
May 22, 2010 | Microsoft Standard Wireless Optical Mouse
USB Mini Optical Mouse - Model: M409 company Enter not recognized
go to device amanger then uninstall all usb drivers from computer then restart the computrer then it autoinstall all usb drivers.
tehn connect your usb mouse cable to computer try all usb port then if problem arise then your mouse usb chip has issue.
Thanks for using fixya.
Please rate solution if it helps.
Jul 24, 2009 | Computers & Internet
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
Optical Mouse Model AM-3055U will not work on this computer
My same model Argos mouse was auto-detected as a "USB compliant mouse" and it failed to work. Went into device Manager and manually re-installed driver as a "HID compliant mouse" from local drivers and it works!!
Yrs, Mad-****.
Jun 27, 2009 | Toshiba LCD Display for Satellite Pro...
My mouse not working (Idont know why)
Install the drivers for the mouse & recheck. Hope this helps.
Dec 24, 2008 | A4tech Wireless Optical Mouse rfsop-48
My laptop is not able to sense my external USB gemini mini wired optical mouse. My laptop is with my friends one day, but once I started my laptop, the laptop is not respondeing to my mouse. Its red light...
Have you tried the Mouse with another computer?
If you did and it worked, my guess would be a driver issue.
If you did and it didn't work there may be a problem with the mouse.
If you haven't the please do so and let me know what your results are so I can try to help you further.
Thanks
Dave
Oct 29, 2008 | Computers & Internet
Microsoft Standard Wireless optical mouse Model 1025
You need to download the IntelliPoint driver from the Microsoft Corporation website. After you install this driver, you will be able to use your mouse as normal.
Sep 06, 2008 | Microsoft Standard Wireless Optical Mouse
Connecting cordless optical logictech mouse
You should install all the necessary drivers! then it will work! moreover you should give your Mouse model so we can assist you further!
Dec 08, 2007 | Logitech LX5 Cordless Optical Mouse
OPTICAL MOUSE FACING GARBAGE CAN IF IT DOESN'T WORK RIGHT
it sounds like the mouse needs repair but if you could get same mouse or another optical mouse and see if it does the same make sure the area you are using it on is clean and the sensor has direct contact with mouse the model of optical keyboard and mouse i use is a4 tec model the model youv'e got does not last as long the mouse lots of problems with the micro swich buttons after a while they go. if same happens on new mouse then operating system needs re-installing. hope this goes well
Aug 11, 2007 | GE Jasco® 98446 (030878984454) Keyboard...
GE JASHO97985 Mouse Logo
144 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
