Question about Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge
I have an 22in yard machine that is hard to crank. if i put gas in the air filter, it will crank long enuff for the gas to burn off. i have cleaned the carb out 6 times. i work on small engines so i know a little. but this thing has got me. dont know if there is a plate coving up a jet or not. any help please. ps. it has no primer, has an pull choke.
  • tnuts4golf Sep 10, 2010
    i did all of that. thanks for answering back. still will not crank unless i spray carb cleaner at the back gasket. the carb gasket at the engine. when i do that, it cranks but skips just a little. i think its sucking air at that back gasket. i'm going to replace it and try again. what do you think?
  • 183 Answers
This is MTD's engine that they have made for them in China. It is a Honda clone. In the carb, there is a removable jet and stem that must be cleaned very well. Pull the carb. Remove the bowl. Look up from where the bowl screw mounts, you will see a brass slotted jet. Remove it. Next. from inside the carb bore, push down on the brass nozzle that extends up into the bore, it should come down thru the hole that you just removed the slotted jet from. Clean both the nozzle and the jet. Run a very fine piece of wire thru all of the holes in the nozzle. BE CAREFUL not to enlarge the holes, only get them clean. Reassemble. This is one of the more difficult carbs to get clean. Don't forget to flush and dry the fuel tank and fuel lines to remove any debris. Also, check with your local parts house to see if a replacement carb is reasonably priced. Most of the time they are pretty pricey, but sometimes I get surprised by how cheap one is.
Posted on Sep 10, 2010
Testimonial: "IT NICE TO TALK TO SOMEONE THAT KNOW WHAT HE IS DOING. THANKS"
Overfill oil
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air...
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 05, 2010 | Yard Machines Tecumseh 148cc Front Tine...
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
THIS GAS EDGER HAS A PRIMER BULB. I PUSH IT THE RECOMMENDED TIMES. THE ENGINE STARTS AND RUNS FOR 5 SECONDS AND KILLS. I HAVE PULLED THE GAS TANK AND EMPTIED IT. REINSTALLED AND PUT IN FRESH GAS. I KNOW IT...
The jet in the carburetor is clogged if it is a 4 cycle unit or the diaphragms are stiff if in a 2 cycle unit. It is burning the primed fuel but can not draw any more fuel to burn to stay running.
HTH
Good Day
Nov 20, 2009 | Yard Machines Red Edger
OUr Yard Machines mulcher is leaking gas (big
At the gas filter? Air filter? Is it a Brigg's? If it is the gas filter, are there clamps that need tightening> Is it the right filter? The hose size is most important. If it is the air filter and it is gushing out, then you have a stuck float in the carb. Hope this gives you some ideas.
Jul 10, 2009 | Garden
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 11A08MB006 22Inch 139cc MTD OHV Gas Powered Side Discharge Logo
336 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
