Question about Dual Car Audio & Video
I just installed my dual xdm7615 and it wont turn, i double checked all my wiring and it is good, why wont it turn on?
I have the same problem. but if i manually pull it down it works fine.. but as soon as it closes it turns off and don't turn back on till i manually pull it down any ideas as to why this does this?
Posted on Jan 04, 2013
    Genius:
  • Dual Master
  • 1,550 Answers
Check the radio fuse and the auto fuse
Posted on Sep 10, 2010
2000 Bonneville, 3800 wont start after changing wires and plugs
check each wire to be at good spark plug number with the image
Nov 07, 2013 | 2000 Pontiac Bonneville
Where can I get a manual for dual xdm7615
You may download a copy of the manual here.
Nov 06, 2012 | Car Audio & Video
Wire touched bare metal and now it wont turn on.
did you check the fuse for the stereo? sometimes if the wires touch it will burn out a fuse.
May 11, 2012 | Dual Xr4115 Mechless Digital Media...
I have the dual amp xpa 2500 and i ran all the wires and everything but the indicator light wont turn red nor green what can cause that problem?
Check all the wiring again. If you can use a multimeter, make sure your power wire is getting power at the amp. Also, check to make sure your ground is good. Also, check the remote wire for 0.5 amps when the radio is on. This will make sure it sends the signal to turn the amp on. Also, check all your fuses. Make sure to put the fuse in your power wire. Hope this helps.
Aug 22, 2011 | Car Audio & Video
I have the "Dual XDMA7650" receiver installed in
sounds like you have the two wires red and yellow mixed up. you want the memory to be constantly on so then the memory cannot be lost, and the red accessory to be switched on when the ignition is in the on position.The ignition, if on will allow your stereo to begin running.
Dec 02, 2010 | Dual Car Audio & Video
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
My Dual XDM7615, will not even shut off and no buttons will work at all, it wont open or change stations and only plays radio on a station that sounds like AM,remote controll has new battery and wont even...
unplug the reciver from the back of it and wait for 20 sec. and plug it back in, this should allow you to eject. now turn off your car and jush eject, when it opens to eject's push the release button on the back of the face like your removing it but instead force the face to completely go down, as far as it will go. now turn your car on and put a cd in and see if that works for ya.
Jan 24, 2010 | Dual Car Audio & Video
Dual XDMR7710 player wont save settings
Cut the red and yellow wires and cross them to the opposites and connect again and this will save your cd players memory
Mar 11, 2008 | Dual XDMR7710 CD Player
Car Audio & Video Logo
528 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
