Question about GE JTP86 Electric Double Oven
Microwave overheated - stopped working - cooled down - light came back on - display says RESET - we reset clock - systems work but it does not heat - is there a reset function for heat?
  • 213 Answers
SOURCE: MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Posted on Nov 19, 2007
SOURCE: Microwave stopped heating
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Posted on Feb 20, 2008
ginko
  • 19396 Answers
SOURCE: Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
localwonder
  • 6784 Answers
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Posted on May 27, 2009
The bottom oven in is not heating.
I would call the service repairman , probably had a element go bad
Jan 06, 2016 | Ovens
How to reset oven
Are there any lights showing on the display at all? If so usually you can reset the clock by holding down the 2 left hand buttons down then using the plus minus buttons to set the time
Nov 10, 2013 | GE Ovens
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Yesterday I "self-cleaned" by oven.
    Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
    Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
    Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
    Feb 18, 2011 | Jenn-Air Ovens
    Microwave dead
    It has a reset button and two fuses her is the break down of unit.
    http://appliancepartspros.com/partsearch/model.aspx?model_id=257786
    but you should get a higher rated microwave.
    Nov 26, 2009 | Ovens
    My wall oven's heating elements stopped working. Clock, enterior light still work.Model REG74BL*3
    Sounds like one leg of the 220v ele. supply has tripped. All thats working, works off of one leg. The elements need both legs to heat. Find your breaker for the oven, reset breaker. It may look ok, but flip the breaker off and then back on. This should fix it.
    Please rate solution
    Sep 02, 2009 | Frigidaire Ovens
    Jenn-Air JMC7000 Microwave Stopped working
    take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
    Dec 01, 2008 | Ovens
    DOUBLE OVEN,GAGGENAU
    this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
    ring 08705 678910 for service and advise
    good luck
    Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
    GE JTP86 Electric Double Oven Logo
    403 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
