Question about Sub-Zero Refrigerators
My subzero 590 was working fine and then just stopped--no fridge, no freezer, no lights. Have power to the fridge, though the master power switch (which is on) will not budge. Any suggestions?
  • Sub-Zero Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Subzero 590 shut off can't find reset button to turn back on fridge
There is no reset. There is an on/off but it doesn't trip. You should check the breakers at the breaker box and then call for service if the one for the refr isn't tripped
May 23, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
The temperature controls for the refrigerator are not responding. The freezer controls respond just fine. My fridge is set to 34 and I need to get it back to 37 but it won't change the numbers.
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 14, 2009 | Sub-Zero 650 / O Bottom Freezer...
SubZero fridge problems
Ice buildup on the back left wall is the sign of an evaporator leak. Not something you can fix yourself, at some point it is going to be completely out of gas, I would call for service now
Apr 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
diane.white@subzero.com
Sep 18, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
416 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
