Question about Lutron Electrical Supplies
I had a Lutron GRX-3106-CE-WH that suddenly out defected with no light. I have a spare switch and connected to the same power source and it was working. I'm seeking for repair service in Hong Kong. Thanks
SOURCE: ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
After a bit of trial and error I found that one of two internal fuses had blown. You can bridge the fuse with a bit of solder to fix it but this means if the same thing happens again there will be no fuse to protect your DS. My own solution is to get a friend to charge my battery on their DS while I wait for a desktop battery charger to arrive from Hong Kong. I found the battery charger on ebay. I suggest you charge your battery in a friend's DS and put it back in your own to see if you DS works. If it does then you have the same problem as me.
Hope this helps.
Posted on Jan 14, 2008
SOURCE: Power buttone notworking for Emachine T3624
Power problems are not always the power supply. A small amount of power is sent to the mobo to perform self test, and if the computer is ready, it signals the supply to turn on the rest of the power. That's to prevent a small problem from cascading into a large one. But it is difficult to troubleshoot. The problem could be with the mobo or the CPU. That's why you need to find a reliable repair shop with people who know what they are doing...not someone who only knows how to swap parts and calls that "troubleshooting."
Posted on May 31, 2008
SOURCE: LG 910 Internet Settings Problem
i had the same problem with my 910 , i rang my service provider and they text me the codes and software to load directly onto my phone , problem fixed straight away !
Posted on Feb 13, 2009
  • 50 Answers
SOURCE: I live in Hong Kong and need to play cd's from all regions
1) Remove disk (if any) from the player
2) Turn the player off
3) Turn the player on
4) Open tray
5) On remote press 9-7-3-5
6) A box should appear on the screen with a region number inside (1
for players sold in USA)
7) Use Up and Down arrow keys on the remote to select desired region
(0 means region free)
8) Press Enter on the remote. Tray should close.
9) Enjoy
Posted on Jun 21, 2009
  • 107 Answers
SOURCE: I am trying to install two Lutron dimmers in the
My first thought is that if you were using these devices to replace existing light switches, the MA-S8AM has an additional electrical connection that wasn't necessary with a light switch or the MA-600. The MA-S8AM has an addtional screw on it (I think its silver in color) that connects to the neutral wire in the circuit. Hopefully you have a bunch of white wires all wire-nutted together in the back of the box - pull a connection from there and attach.
If that's not the issue, then I would call Lutron's tech support. They're available 24/7, so you may as well. They're at 1-800-523-9466.
Posted on Oct 22, 2010
Why did the remote suddenly stop working?
Try disconnecting power at the source, not a switch. Wait for a minute or so and turn on the power again. This action may "reset" the receiver. You also may find that remote control is restored after a power outage. Finally, if nothing else works, you may have to install a replacement Lutron receiver.
Aug 16, 2015 | Lutron Electronics MIR-ITFS-LF-WH...
Lutron s-600 don't seem to function
That switch says on it that it is for fluorescent lights only. I don't know if you can use compact fluorescent bulbs on that system, perhaps verify if you can or not. The switch has electronics in it and may need that ground wire to get 120 volts to operate. If you have incondescent light bulbs return and get the correct dimmer.
Mar 16, 2013 | Lutron S-600-wh Skylark Incandescent...
My Lutron dimmer/lights suddenly will not turn on. all electricity works throughout the house. The green light that usually is lit on the panel is not on either. any suggestions?
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Nov 15, 2010 | Lutron #MA-LFQHW-WH 300W White SP Light...
I have a DL-3PSLHW-WH switch with no wiring diagram. It is single pole or 3-way. Need diagram.
You posted under Lutron 3-way dimmer.
You didn't say the number of screw terminals on device or color of those screws.
If your device has two brass screws, then it is single pole.
If your device has 2 brass screws and 1 dark screw, then device is 3-way
If you are replacing 3-way switch, identify wire on dark screw >> connect this wire to dark screw on dimmer. Other two wires connect to either brass screw.
If device has wires instead of screws, the color of those wires is an important clue.
Answer back with the colors of those wire and it is easier to help.
Different dimmers are suitable for different types of lighting.
In an effort to help you, I searched my files for Lutron dimmers.
Lutron has 17 dimmer types, with numerous models under each type
They don't show DL-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Lutron has NT-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/NovaTDimmer/Pages/ModelNumbers.aspx
The NT-3PS is a 3-way dimmer.
Here is wiring manual:
http://www.lutron.com/TechnicalDocumentLibrary/wallbox_wiring_6_7.pdf
If the help above does not get you going, answer back with more information and we can help.
Oct 24, 2010 | Lutron Dalia 3Way Dimmer 600W- White -...
How to program control with light switch
If I understand correctly, you have the Lutron Pico wireless control
And you have the Lutron Maestro companion switch or companion dimmer
Pico will not work with ordinary wall switch or dimmer >> it has to be a companion product from Lutron
I have read the PICO wireless manual, and it shows no instructions for communicating with the companion wireless switch or companion wireless dimmer
http://www.lutron.com/Products/SingleRoomControls/MaestroWireless/Pages/Overview.aspx
http://www.lutron.com/TechnicalDocumentLibrary/369-144f_Pico_Wireless_Control_SpecSub%20%286%29.pdf
I have read the 120V Companion switch manual and it shows no instructions for communicating with the PICO wireless control
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Single+Room+Controls&prodn=Maestro+Wireless%C2%AE
http://www.lutron.com/TechnicalDocumentLibrary/030865c.pdf
1-800-523-9466 for technical support
Technical support online appears at page bottom
Normally manuals give you some clue as to how the product works.
The PICO manual says it's easy to control lights (I guess it's easy for mind-readers)
There seems to be no answer or hint when working with the PICO.
I think Lutron tech support is where you go from here.
Let us know what you discover
Oct 22, 2010 | Lutron MRF-VCTX-WH Maestro Wireless White...
I am trying to install two Lutron dimmers in the same box. The dimmers are models MA-S8AM-WH and MA-600WH. I can get get the MA-600-WH to work but not the MA-S8AM-WH. Anyone have any hints.
Aug 25, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Open Questions:
Electrical Supplies Logo
69 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
