Question about Movado Eliro 0605377 Wrist Watch
What is the correct battery model for the this watch?
  • ilander65 Sep 10, 2010
    This is all obvious information. The only real answer worth paying for is the actual battery model number. To me what you sent me basically says "i don't know the answer but here are some people to ask"
    President:
  • 2,777 Answers
If you are attempting to replace it yourself, when you open the back it will clearly have the battery type labeled on the actual battery. If you are unsure of how to take it apart I would just take it to a watch store, most towns have a watch store that will replace a quartz battery like this for less than $10... I would just have them do it.
If you are capable enough of taking apart the watch then you definitely can just find the battery type. If not, then don't worry which type they are are very inexpensive.
Tim
Posted on Sep 11, 2010
  • 3,083 Answers
I couldn't find anyone with the battery type/number. Since this is a high-end watch, I would call a reputable dealer and ask them how/'who to contact. I saw on a couple of web blogs that this watch has a lifetime free battery replacement, so contact Movado to find out how to get this done. Here's their website:
http://www.movado.com/AboutMovado.aspx?Id=/Home/AboutMovado/Events
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 10, 2010
What is the proper battery for my Gucci Watch model 3000
Don't be cheap!!!! Go to a reputable jeweler. Most of them are very clued up on these watches and they will give you the correct information. There are many types of batteries and sizes of batteries. There are also a variety of movements for battery watches. If the wrong battery is put or forced into the watch you can do damage to the watch and then will become more expensive to fix!!!
Mar 28, 2013 | Gucci Watches
Had new battery installed in Howard wrist watch, cannot get the correct time. The date is correct.
You don't say which model you have but if it is a radio controlled watch, then try re-setting the location, it frobably "forgot" where it is and wen back to the original factory setting.
Jul 17, 2010 | Watches
Watch has no power. How do I power it back up?
The catalogue says "never needs a battery" and as it is a "radio controlled " type, then it must have a battery that is charged by power generated by motion.
To get the watch to go, then you should wave it backwards and forwards for some time ( 100's of times according to one maker!). This will charge the battery.
Leave the watch overnight so that it can pick up the timing signal and correct the watch. I did this with mine when the battery was changed and it lost its time and it took a couple of days before it told the right time, so be patient.
If the watch refuses to show any sign of life, then it should be returned to an authorised repair agent for inspection.
Mar 17, 2010 | Citizen Blue Angels Skyhawk Watch
What is the correct battery for my freestyle model 750
The manufacturer does no recommend that you replace batteries yourself (presumably to ensure that it retains the waterp.roof seal)
See excerpt from their web site support.
"Do not attempt to repair the watch yourself. It is strongly recommended that a certified jeweler, watch repair technician or Freestyle service center replace your battery. This will help in preventing water leakage from improper battery replacement, which is not covered in your warranty. "
Dec 27, 2009 | Freestyle Shark Buzz Wrist Watch
Directions for setting correct time with Smash Watch 05-0407
You need to reset your watch completely and to do that, you have to start from battery.
Extract watch battery completely and leave your watch without energy supply for an hour. This will erase any data kept in watch memory.
Then put the battery back in watch exactly the way it was and reset your watch using pushbuttons.
Don't forget to rate, please.
Jan 14, 2009 | Bulova Watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Movado Eliro 0605377 Wrist Watch Logo
215 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
