Question about Dryers
I need a manual... i need to know how the belt hooks up
    Brigadier General:
  • 3,301 Answers
Which drier are you looking for ?
Posted on Sep 10, 2010
  • Canwoodjc
    Canwoodjc Sep 10, 2010
    here, this is a very good site with images, On how to get to and replace your drier belts http://repair2000.com/wpoolbelt.htm
Timing after installing new belt
There are about 3 MAIN delicate issues here, could be needle bar, top shaft or bottle shaft, to understand timing first knowing that needle hook is passing the cusp of the needle on its way up....
Feb 25, 2014 | SewShop.com Singer Model 758 Touch & Sew...
When we put the head on the belt will not work
Check to make sure the belt has been "scooped up" by the hook in the head. When you turn the knob on the head to remove it, it's supposed to "scoop" up the belt and pull it away from the shaft. If you don't have the belt on the hook when you place the head back on that means the belt isn't going around the shaft. You can just use your fingers to place it in position so the hook will grab it and then place it back on the body, rotate the know and it should be in contact with the shaft. The only other problem could be that the belt is broken and needs to be replaced.
Mar 13, 2013 | Kirby Vacuums
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
How can i get a manuel . I don't know how to hook up the parts for the shampooer to clean carpet . Need ASAP.Kirby vacuum model #293001 serial G.
I haven't been able to locate Kirby manuals, but they do have good instruction videos for hooking up the shampooer, changing the belt, etc. Just click on the video you need.
http://www.kirby.com/Portals/0/videos.html
Oct 08, 2010 | Vacuums
Latch belt too short
Looked at the owner's manual of my car and realized where I needed to hook the latch belt hook strap. I was trying to hook it to the wrong thing. Car seat works great now!
Nov 21, 2009 | Safety 1st Baby Gear
I need a belt diagram for a Landpride 6' finish mower.
Check out their website and look under manuals. http://www.landpride.com/main_products/main_gm.html
If you don't find it there, I'm sure customer service could hook you up...
May 28, 2009 | RTO Farm Pro Finish Mower 5' Rear...
Replacing belt on washing machine
Hi!
Welcome to Fixya,
in replacing a belt please follow this step:
  • turn off and unplug your washer.
  • hook the belt first in drive motor pulley. ( a slot where your belt take place on top of the motor and sure that the belt is in place firmly to the slot of the pulley.)
  • start to hook the other end/loop of the belt to the tub pulley in one side of the pulley (it is more efficient in starting to hook the belt from inside to outside rotation.)
  • and hold the belt and rotate inside the pulley of the tub slowly
  • dont let the belt slip outside the slot of the pulley hold it firmly with your hands
  • hold the belt, clip to the slot of the pulley
  • but don't hold the belt alone or don't hold the belt in between of the pulley.
  • hold the belt inside the slot of the pulley in the tub pulley and rotate slowly. until it fix to the slot of the tub pulley.
If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
aclamonte
Dec 09, 2008 | Washing Machines
Attaching the Belt
Leslie,
Rotate the square knob on the front of the attachment to the "Belt On" position (green marker). Insert your fingers in the attachment port (the round opening on the back where the "hook" is) and position the belt so it's centered and as high up as it will go (that's usually just below the center of the opening. THEN rotate the square knob on the front to the "Belt Off" position. You should feel the belt tighten up and the know harder to rotate.
TJ
May 02, 2008 | Kirby G5 Bagged Upright Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Sentria
If the green light is off, then its time to replace the band. This video shows you how.
Jan 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Dryers Logo
26 people viewed this question
Top Dryers Experts
