Question about Hampton Bay 24002 Ceiling Fan
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
  • mjsorl
    mjsorl Jan 02, 2013
    Believe it or not got all of my parts at Lowes when replacing the internal switch.
    Brigadier General:
  • 3,301 Answers
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Posted on Sep 10, 2010
Green to Ground always first!
White to White next!
Black to Black
Red / From house wiring = HOT same as black. Do not tie to BLACK. If you have a light this is the feed to the black/blue wire from the light package.
Posted on Sep 23, 2012
  • 10865 Answers
SOURCE: I purchased a display Model
Hello. Here is the owner manual for your fan http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41228.pdf
j.
Posted on Aug 27, 2010
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
SOURCE: Wiring a Hampton Bay ceiling fan
we are installed in new fan which is the glendale model what is the purpose of the red wire. Do we connect them with the black and blue wires?
Posted on Jul 06, 2008
  • 726 Answers
SOURCE: hampton Bay fan wiring
this is everything u need to no
'http://www.ceiling-fans-n-more.com/ceiling-fan-wiring.php
it has all the colors and a diagram for you
Posted on Sep 29, 2008
20 year old Hampton Bay fan requires new 3-speed pull chain fan switch replacement. I did not copy the wiring pattern for the L, 1, 2 and 3 positions. There are 3-wires: black, white and blue.
Typically AC wire protocol designated black = line voltage (means \'death\') and white is neutral (cold).
The blue one will be a switched line to the motor and a meter capable of checking continuity should allow you to determine the proper wiring.
Oct 14, 2014 | Hampton Bay Dryers
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Need a wiring diagram for a hampton bay ceiling fan
most of the manuals have wiring instructions - check out any one of the manuals here
Jul 12, 2012 | Hampton Bay 24002 Ceiling Fan
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Wiring?
You have two switches right? One for the light and one for the fan? White should be neutral. Green should be ground. Black should be hot from one switch and red should be hot from the other. Hook black to black and blue to red. If you wire blue and black together then one switch will turn on the fan and the light at the same time.
Feb 17, 2009 | Hampton Bay 48670 Flemish Pewter Finish...
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
4,507 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
