Question about Whirlpool Microwave Ovens
WHIRPOOL MICROWAVE Model # MH1150XMS-3. I NEED TO REPLACE THIS UNIT FOR ANOTHER MODEL WITH SIMILAR CARACTERISTICS
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave Whirpool burned - model #mh6150xhb-0
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool MH1150XMS-3 F2 error message
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is 8205031 (formerly 8204739) and you can get it here for $140.37 plus shipping.
You can also find helpful exploded view diagrams at that link.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
  • 400 Answers
SOURCE: HOW DO I GET TO THE HANDLE ON A WHIRPOOL OVER THE
Look here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135344&diagram_id=1301811#d1301811 Perhaps there are other places. Do a google search for mh1150xms parts. I hope this helps you.
Posted on Nov 20, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave Model # MH1150XMS-3 F2 Error
"F2" on a Whirlpool means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable, too.
On some models, you have to peel off the old keypad and stick on a new one.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple DIY job.
You can find helpful exploded view diagrams and order parts by entering your full model number (with suffix) from the tag on the oven
here.
If you have to replace the frame, you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Jul 10, 2011
heatman101
  • 43501 Answers
SOURCE: Whirpool Micro Wave oven turntable
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 21, 2011
Whirpool Micro Wave oven turntable not working model MH1150XMS-2
heatman101
Aug 21, 2011 | Whirlpool Microwave Ovens
Microwave Model # MH1150XMS-3 F2 Error (Short in membrain keypad
here.
Jul 07, 2011 | Whirlpool MH1150XM Convection/Microwave...
Mh1150xms-1
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You will need to enter the full model number with no dashes, e.g., MH1150XMS1.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 29, 2010 | Whirlpool MH1150XM Convection/Microwave...
Blue oil film
it may be the oil/paste out of the h.v. capacitor in the unit,if thats what it is,soon it will dry out and overheat the cap and blow the internal ceramic fuse,i'd for sure find out if this is the problem cause it won't go away
Oct 15, 2009 | Microwave Ovens
William E. Miller
prototech@usa.net
Sep 09, 2009 | Microwave Ovens
Whirlpool microwave model MH1150XMS-0 is not working
your door monitor switch has gone out. they are 3 switch that monitor the door. remove control panel. they are located behind frame where the door clips go into.
Jun 24, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
Most likely needs a new membrane switch. Model MH1150XMS-2
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
Aug 07, 2008 | Whirlpool Microwave Ovens
Microwave mh1150xms-4 code f2
F2 on a Whirlpool is a failed keypad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
Jun 10, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
