Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I have MTD Yard machine and don't know if it is 2 or 4 cycle. Oil should be-SAE30. Can I use oil for 4-cycle which they soid me i Can. Tire.(M otomaster)
  • 183 Answers
If your mower has seperate fill caps for the oil and the gasoline, then you have a 4 cycle or 4 stroke engine. In this case use SAE HD30 motor oil. If there is only 1 fill cap and it says oil & fuel mix, then you have a 2 cycle or 2 stroke engine.
Good luck
Posted on Sep 10, 2010
Can you buy a service manual for mtd tiller
Every 25 hours change the oil using SAE30 or 10W30 oil. Go online to the manufacturer for service manual.
Aug 18, 2014 | Garden
What oil do i put in my yard bug?
use SAE30 four-cycle small engine oil
Jun 19, 2012 | Measuring Tools & Sensors
What kind of oil shoukd I use on a 24"cut MTD yard
I'm assuming you have a Tecumseh engine on there. But a Briggs would be the same. This is straight from Tecumseh, though (long story short is run 5W30 Oil or 0W30 Synthetic in it assuming winter temperatures:
Oct 26, 2011 | Mtd 22" Yard Machine Push Mower
What type of oil does it use?
I think all of these 4-stroke trimmers use SAE 30HD oil. I recommend synthetic. If you use synthetic, you can get away with using a multi-viscosity like 10W-30 if you can't find straight SAE30 synthetic, but don't use muti-viscosity conventional oil in these machines.
Sep 10, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Where can I get the type of oil needed for the yard machine(22 in) push mower?
You can use regular SAE 30 weight oil from the auto parts store. If you use multi-viscosity, make sure it is synthetic, otherwise use straight SAE30 oil.
May 27, 2011 | Mtd 22" Yard Machine Push Mower
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
Sep 03, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machine push mower needs oil changed. How do I know how much oil to put in it. No Dip Stick
when you unscrew the oil cap is should have an oil level mark on the side of it.
Jul 27, 2009 | Mtd 22" Yard Machine Push Mower
What type of oil to use when changing oil
For any four cycle engine (engines with separate oil and fuel fill locations) use high quality detergents in the following viscosity.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
(From the MTD answer pages). Best regards, --W/D-- Please feel free to rate my solution. Thanx.
Jul 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What oil do I put in my 4-stroke Troybuilt weed trimmer?
According to troybuilt, here's their info.
K
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Oil? Gas? Additives?
Small engines like to see SAE30 oil. This is assuming a 4 stroke engine of course (if you have an oil filler spout and dip stick you have a 4 stroke engine). Use regular unleaded gas, and personally I mix STA-BIL into ALL of that gas I use with my small engines. I have too many carburetors to take the chance of needing to rebuild them in the spring.
Manuals for MTD products are here: http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need model and serial numbers
Apr 27, 2009 | Mtd Heavy Machinery
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
164 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
