Question about Sony HDR-FX1000 Mini DV Camcorder
My Sony fx 1000 keeps telling me head cleaning I have run a cleaning tape through it a few times but the message keeps coming If I switch to VCR then back to camera it allows me to film but as soon as I stop recording I have to switch to VCR again then back to camera before I can record again please help
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 10, 2010
Cleaning cassette message
I assume you mean you've got a message come up telling you to clean the cassette recording heads. The camera has detected either that the heads are getting dirty, or sufficient time has elapsed that they could do with a clean. By a cassette cleaning tape - which looks like a normal tape but with white papery stuff - follow the instructions and run it for the recommended time. Hopefully this will cause the message to disappear.
Aug 25, 2014 | Video Cameras
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
thanks
Aug 04, 2008 | Televison & Video
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
I took out some 2001 9/11 taped back then. Inserting them the TV message was CLEAN VIDEO HEADS. I don't know how to do this. Are the video heads on the VCR or on the video tape? What would i use to...
You can purchase a VCR cleaning tape that will do the job. However the best way is to buy a can of Servisol Video 40 (small one will do and it will last a long time) then remove the top cover of the VCR. Spray the VCR heads. Shinny Silver things and any moving parts that the tape touches. If your not certain what to clean, with the cover off insert a tape and press play. Remove the tape and spray small amounts on the surfaces. If you can see a lot of dust you can wipe the heads etc with a cotton bud. A VCR housed in a smokers house will need extra work to get it clean. Once dry you can test a tape. If you see flecks or spots the VCR will need further cleaning.
Sep 13, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I need to clean the heads of my vcr
The best method is to open the top cover after UNPLUGGING It from the wall socket. Take a clean white paper and wrap it round your index finger and press that finger on the whole surface of the shiny drum with circular lines on it. Now keeping even pressure on the drum, rotate the drum by touching only the top part of the drum with the other hand. After rotating it a few times you will notice when you remove the paper it will have some black lines or mark.That's the dirt that prevents the picture from coming. You may have to do it a couple of time before you get the picture. Be careful not to move the paper finger or you could damage the head. You can also wet the paper with surgical spirit to clean only remember TO DO A DRY CLEANING AFTER THAT before you inset a tape for testing.
Mar 08, 2011 | Televison & Video
Playing Tape to End Requires Head Cleaning Every Time
it seems your tracking needs to be looked at.also have a look at the tape open front section button at side slide open with your finger.look at the tape toward the light,if the edge of the tape is a bit wavey not straight you will need an alighnment as well.
Apr 26, 2010 | Sony DSR-11 DV / Mini DV VCR
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Tracking
Does this happen on ALL tapes?
Depending on WHICH model VCR you have (old or new) SOME have a switch which will allow you to adjust tracking MANUALLY. When the switch is in the manual position, it won't track automatically. If some played with that switch, that could cause your problem.
ALSO, do you have a cleaning tape? If the control track head is dirty, it won't see the "control track" (which gives you VCR information to control the tracking.
Another possibility is one of the video heads (there's 2 or 4) is dirty, and without ENOUGH video signal coming off the heads, it's not possible to track properly.
Try running a cleaning tape through. If you've never done it, it might be time. Unless yu know about equipment I'd wouldn't suggest you open the machine and clean it yourself. Let me know how you make out.
Mar 16, 2008 | Sylvania 6260VF VCR
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Sony HDR-FX1000 Mini DV Camcorder Logo
182 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
