I have a White Westinghouse shelf stereo. It has a 3 cd changer. The changer had one cd in it but would not rotate or eject. I was able to take cover off and remove the one cd. However, the changer still will not turn nor open. All other functions are fine. Any advice?
techman
  • 3130 Answers
SOURCE: CD Changer
Have you tryed to use a lens cleaning disc, or cleaned the lens your self manually/
Posted on Sep 11, 2006
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
tech48
  • 624 Answers
SOURCE: bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
Posted on Jul 01, 2008
  • 3422 Answers
SOURCE: RCA RS2025 Bookshelf Stereo CD Player Hangs Up
Ok,
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
Posted on Sep 04, 2008
freetek
  • 5568 Answers
SOURCE: CD CHANGER EJECT BUTTON
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Posted on Oct 28, 2008
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
RCA RS2664 Stereo
Do you know by any chance if a CD might be stuck inside?
Does the device power up?
Apr 09, 2008 | RCA RS2664 Shelf System
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
I also have a LG FA163DAB what won't eject a CD.
Hi there! I have one of these units and there appear to be 2 LOCKS on it. The first is a general LOCK probably to prevent people from fiddling with the controls while on display on the shopfloor. This lock is activated and removed by pressing the STOP key on the remote and on the front of the unit at the same time for 5-10 seconds. The second lock is a CD player lock which comes on automatically (I think) when the unit is moved to prevent damage to the laser inside. Does anyone know how to remove this lock? It has been on for about 3 days now and it is not explained in the user manual. My CD is stuck inside and I cannot listen to anything else but the CD which is inside the unit!
Jul 26, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
CD changer eject button does not work. Three discs are inside. Changer works. Good sound is produced. But unable to eject disc changer to change discs.
Oct 27, 2008 | Curtis RCD-897 CD Shelf System
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
288 people viewed this question
 Grubhead
Grubhead
