Question about Panasonic KX-T7431 Corded Phone
Good Afternoon I have a KX-T7431. Currently I'm having a really tough time getting my phone extension transfered to an outside line (my cell) when I'm not in the office. Currently command Intercom 71069(cell phone) # is not working..... The manual commands don't seem to help as its so generic for like 5 phone series.
  • Panasonic Master
  • 2,460 Answers
A TD system requires at least 4 things for it to work. Here's an example page with the reference numbers to programming.
http://public.carl.airpost.net/Pana/TD/TD_CF_OffPrem.pdf
Most notably, Class of Service, and permissions in 502 and 504 need to be set for your phone in order to make it work. After that, you'll need to work on the timings and limits.
Carl
Posted on Sep 11, 2010
CO Not Assigned - unable to select and outside line
Did you not assign a speed dial CO buttton to an extension
Mar 11, 2014 | Panasonic KX-T7431 Corded Phone
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
Sep 04, 2013 | Panasonic KX-T7730 Corded Phone
My panasonic kx-t7431 message light won't light up, I have voicemails but it will not light up, please help!
With the headset off, push the intercomm button or SP-PHONE button, then once you hear the speaker is on do do this.
Push the STAR sign which is * and then number 700 and your four digit extension.
For example ( *7000422).
Nov 30, 2011 | Panasonic KX-T7431 Corded Phone
We have a KX-TD816 system and I have a KX-T7431 phone. We have no operator so whoever picks up transfers. No one can transfer to me anymore. One other thing all the phones the FWD/DND button blink slowly....
So what happens when they press TRANSFER and dial your extension? What happens when you call someone with a display phone and your extension comes up on the display?
The FWD/DND button shows that you have a FWD or DND condition set on your phone. Try pressing it one or 2 times and see if the display says FWD to xxxx. Now, if it is cleared, from the intercom dial 7104 (busy) or 7105 (no answer) 165 # That sets the CF on your phone.
If the others have lost your DSS button on their busy lamp fields, and truly nobody can "transfer" calls to you, you can reprogram those with PROGRAM 99 (don't pick up the handset) press the button assigned to your extension and dialing 1 + your extension and STORE.
Carl
Mar 23, 2011 | Panasonic KX-T7431 Corded Phone
Can`t change the hour on my telephone.Panasonic KX-T7431 Digital.
You can, but the real question is will it stay changed? The time is altered by CID or by manual change. If you change it and it changes back, then whatever transmits the time after 2AM is messing with the clock.
As a start try PROGRAM **1234 from extension 101 and dial 000. It will guide you through the sytem time. If it doesn't stay the next morning, then you probably have VoIP or some alternative box sending you the wrong time.
That's a whole other thread.
Carl
Aug 30, 2010 | Panasonic KX-T7431 Corded Phone
I currently use a Panasonic KX-T7431 at work and I wnat to either know does it have an answer machine function within the phone or can I buy one to add to it , we cusstenly do not have any faciity for...
Generally, a 7431 phone plugs into a Panasonic KX-TD phone system cabinet. The 1232 starts as an 8 line 16 phone cabinet, the 816 a 4x8, and the 308 a 3x8. To those systems, you can add a TVx Panasonic brand voice mail system, or even a plain old ansering machine. Both would need to be probrammed by someone familiar with ringing and intercept groups in system programming.
A quick call to your Panasonic installer or dealer would be the best, as it's beyond the scope of this forum to provide instructions.
Carl
Aug 17, 2010 | Panasonic KX-T7431 Corded Phone
How do I change the Name of the person at an extension on the Panasonic KX T7431
press the Program Button, then (**1234), and scroll counter-clockwise through the options with the volume circle. the option should say, "004 ext name set." to enter into that option to change, press the sp-phone button. continue pressing the sp-phone button until you find the extension number you would like to change. once you find it, press the transfer button and spell the designated name using the dial pad. For example, Mike (press 6 and use the volume circle to browse the letter you need from that assigned key- to get M) to continue spelling the name, continue using the dial pad and repeat to assign the designated letter. to store the name, press the "Auto Dial/Store" button and it will beep to confirm.
hope this helps, deanna
Jun 28, 2010 | Panasonic KX-T7431 Corded Phone
Problem with extension and voicemail
1. Can be done but you have to have installer access to the system. You could also move the extensions at the phone system.
2. Is his call forwarding set (720x 165 #)? 720 sets forwarding for both intercom and outside calls.
Jan 13, 2009 | Panasonic KX-T7431 Corded Phone
Panasonic KX-T7431 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
