Question about Logitech Z-10 Computer Speakers
My logictech Z10 speakers don't reset when I turn them on and my lcd manager can't recognise them. this problem occurs occasionally. when i turn the power on the light on the speakers comes on then doesn't go out and I can't turn them on. sometimes, when the speakers are working OK, the LCD manager doesn't recognise them and I have to turn the laptop off and then on again, sometimes a number of times until the manager recognises them. this occurs whether the speakers are connected via a hub or directly into the laptop.
sigma_shiva1
  • 188 Answers
SOURCE: Z10 USB connection does not work
try other usb port.........
if problem still remain.....write again............on fix ya .com
Posted on Oct 27, 2007
  • 43 Answers
SOURCE: X-530 with LCD Vizio TV
you need to go to radio shack and buy a y plug to be connected between tv and computer. unless i miss understand you...
Posted on Dec 07, 2008
  • 45 Answers
SOURCE: tried to connect to samsung lcd no sound
Plug the green lead on the speakers into the headphone socket on the television. You may need to go into the menu to turn up the headphone output. Turn it to 70% on the TV, then use the volume control on the speakers
Posted on Jan 10, 2010
  • 60 Answers
SOURCE: my desktop pc wont recognise my speakers
Go to the control panel, open device manager, check the sound system. If you have installed a new O.S., then you will need to also install a new sound system. Perhaps it ac audio 97 or some other. Look for yellow exclamation mark or yellow question mark and right click on that and update drivers.
Hope that helps.
Posted on Jul 05, 2010
bronk50
  • 27725 Answers
SOURCE: Logitech X240 speakers which worked
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Jun 05, 2011
How do I raise volume on Logictech speakers Ls121
You mean LS21 speakers?
You turn the control on the separate control unit. I had similar Logitech speakers. I couldn't stand the hissss when they were turned OFF! I now have Bowers and Wilkins MM1 speakers which are amazing!
Amazon com Logitech LS21 2 1 Stereo Speaker System Electronics
Dec 17, 2015 | Audio Players & Recorders
Z10 no light
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
hope it helps
Dec 01, 2011 | Logitech Z-10 Computer Speakers
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Jan 29, 2010 | Pentax Optio Z10 Digital Camera
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
LOGICTECH X-530
That speaker equipment should've came with an adapter to audio cables
its a rectangle that has 3 ports (orange,black,green) that lead out to 2 ports (red,white) from there u need the audio cables or AV cables
connected the red/white prong to the red/white ports on the adapter.
then connect the other end to the back of the tv where you will c white yellow and red
for dvd player connect it to the white and red ports
dont wry about the yellow 1 that is for video
Oct 18, 2008 | Logitech X-530 Computer Speakers
Logictech X-240 computer speaker....I got no instructions.
I connected every thing like it stated in instructions. and can-t get the sound to come out of the speakers. What do I do wrong?
Aug 22, 2008 | Altec Lansing Multimedia Computer Speakers
Logitech Z-10 Computer Speakers Logo
341 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
