Question about Motorola Mobility Hint QA30 Cell Phone
Motorola Hint top row of buttons won't work (sometimes)
    Problem Solver:
  • 15 Answers
Maybe it's the connection between the mobile parts.
Posted on Sep 10, 2010
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Tip
How to Sync Stylus with LeapFrog Leapster 2 Learning System
If you need to sync the device to the stylus just follow the steps below.<br /><br />1. Turn your <span>Leapster</span> 2 off, and remove the game cartridge<br /><br />2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.<br /><br />3. With your finger still firmly on the 'hint' button, turn the <span>Leapster</span> 2 back on. Keep your finger on the 'hint' button.<br /><br />4. The screen should be displaying the calibration screen. You can release the 'hint' button now.<br />5. Press the 'A' button on the right to enter the calibration screen.<br /><br />6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your <span>Leapster</span> 2 throws at you.<br /><br />7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.<br /><br />8. Your stylus and touch screen should now be working, enabling you to sign in as usual.<br /><br />9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.<br /><br /><b>Thanks for <span>using</span> <span>Fixya</span></b>
on Mar 09, 2011 | Toys
Game 100 professor layton and the curious village please solve
Most of the squares you make will be tilted 45 degrees to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares at a diagonal. Hint 02 You want more specifics? All right, here's the location of one of the squares. Connect the four pins in the top-left corner to form a tiny square.
Just so you know, this is the only square on the board that isn't tilted. Hint 03 The largest square contains the pin that's third from the top on the left column and the bottom pin from the far-right column.
You also need to form a small diagonal block using the two pins lined up diagonally on the bottom-left portion of the board. There are two more small squares just like this one on the board. Solution For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
May 31, 2011 | Nintendo Professor Layton & the Curious...
The touch screen does not respond to the stylus what can i do?
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
I have a motorola karma the back button wont work if my cell is open but it works when its closed also the down button doesnt work.and now the a button doesnt work either ? ive only had it for about 3...
So the phone I have is the motorola hint, QA30, actually identical in design (except square, red and black) and I have similar problems, my right navigator (right shoulder) and my up and left buttons, as well as my send button, will randomly stop working, I find (in all seriousness, no joke) that sometimes hitting the phone (lightly of course) seems to get the buttons to work again,
Jun 17, 2010 | Motorola Mobility Karma QA1 Cell Phone
Lock code
the lock code for motorola hint, should be 1234, or 0000.
if this doesn't work, pres the back button then press # , type the las four digits,
if nones of those works, call your service provider
Apr 28, 2010 | Motorola Mobility Hint QA30 Cell Phone
How to turn off motorola T289 two way radio
On your left hand side as you face the radio, there is a row of buttons. The top button is the power button.
Here is a link you can copy and paste for the owners manual. (Click T289 PDF in the upper right hand side of the page to download)
http://www.usersmanualguide.com/motorola/2-way_radio/t289
Jan 18, 2010 | Motorola Talkabout T289 (14 Channels)...
Motorola hint _HELP ME
This happens to me too! I have the same phone, and randomly, for no reason at all, the send button, the up and left buttons, along with the button above the back button, will stop working temporarily, its frustrating as heck because it usually happens in the middle of texting or when I actually need to do something, what I find works, (no joke) is to hit it, the button area, usually (not to hard) a good jostle gets the buttons working for me.
Oct 20, 2009 | Cell Phones
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
Motorola Mobility Hint QA30 Cell Phone Logo
123 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
