Question about HP Computers & Internet
I have a H P Pavillion m7560n. It oiwers up, but the monitor, keyboard and mouse will not function. I have changed the power corf, and the cable to the monitor. I have checked evetry connection, turned off and unpluged both the power and the modem and let them sit at first a minute, then an hour and now over night. Still the same results.
  • jskjerve Sep 10, 2010
    This is not a lap top, I gave you the brand and model, and you tell me to open the case and remove the battery. Could you try again
  • HP Master
  • 11,800 Answers
Last attempt: open the case, locate the BIOS battery and take it out for one hour to reset it. If this fails then the motherboard is defective and must be replaced.
Posted on Sep 10, 2010
  • Azrael SRL Sep 10, 2010
    I said  BIOS battery - it's the round shiny thing on your motherboard.
How do I replace my motherboard? HP Pavillion m7560n
Hi,you can buy it online from notebookparts.com
or if you can take it to any HP service centre in your area.
Jan 06, 2011 | HP Pavilion m7560n PC Desktop
Monitor green light comes on then it says no imput
looks like there is problem with ur signal cable check that monitor signal cable is tightly fixed or contact ur product support center.
Mar 31, 2010 | HP Pavilion F1523 15" LCD Monitor
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
The system would lock up after going into sleep
Try Hard reset remove all the peripherial and power supply connected to the Computer Tower No Mouse, No Keyboard, No Ethernet cable and usb device should connected to the Tower and then press and hold down the power button for 30seconds and then connect only mouse keyboard and power supply to the Tower it should resolve the issue if it will not than set up bench repair this is Hardware issue.
Thanks and Regards
Neeraj Sharma
Oct 16, 2009 | HP Pavilion m7560n PC Desktop
HP Pavillion ze4400 can this laptop use an external mouse & keyboard ?
Any external USB mouse can be connected to the system. As well as USB keyboard. Or specifically if you go through HP, the mouse part number is: NR152AA, and keyboard is GM321AA. As far as non-HP products you will need to check on compatibility on each. Hope this helps you in this question.
Jul 29, 2009 | Computers & Internet
Keyboard not functioning
usb mouse and keyboard depend on ur usb ports and ur bios u should check that ur usb drivers are installed properly or not .n try changing ur keyboard in different usb port . thanks
Feb 24, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Hp pavillion desktop will not power up. Blinking green light at power supply
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
Oct 28, 2008 | HP Computers & Internet
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    No mouse,no keyboard, and no monitor?
    try to connect it with other keyboard,mouse and monitor....if they will run, the keyboard,mouse and monitor may be defective or damaged..but if they did not run properly,,
    maybe somethings wrong wit your unit...
    try to connect it first and see whats the result...
    please tell me what are the results...
    you may post it here...
    chaw
    Jun 17, 2008 | Computers & Internet
    Computers & Internet Logo
    22 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
