Question about GE DBXR463EBWW Electric Dryer
Dryer only runs with start switch held on. as soon as you let it go dryer shuts off............help.ps model dbxr463
  • cfafsn2use Sep 10, 2010
    I just replaced the switch at a cost of 31 dollers and the 6 for you and still got the same problem. now what.
    President:
  • 1,554 Answers
The start switch is bad, replace it. Lift the panel and remove the existing faulty start switch. Use flat-head screwdriver to pry and lift off the switch. Install the new start switch in reverse order then transfer the wires from the old switch ti the new one. Make sure to disconnect power before attempting this repair.
Posted on Sep 10, 2010
  • Jahn27
    Jahn27 Sep 10, 2010
    Check the resistance of the timer resistor. If it reads open, replace it.
Kenmore heavy duty solid state dryer, mdl 1108609420 (???) Starts and all functions work as long as the Start Lever is held up. As soon as you let go of it, the dryer stops. Unable to locate...
repairs should be performed by a authorized repair person.if there is not enough voltage to the relay start switch from the electronic control replace the control. if there is enough voltage to the relay start switch replace the switch.
Jun 04, 2017 | Dryers
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
Dryer starts with a twist switch. dryer starts but shuts off as soon as you let go of the switch
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 26, 2010 | GE Dryers
Dryer won't stay on when button is pushed the button has to be held down for the dryer to run
A centrifugal switch has failed within the dryer. The centrifugal switch maintains electrical flow to the motor after the start button has been released (this is a safety measure) When you press the start button you put power directly to the motor; once started the centrifugal switch then puts power to the motor until the time then shuts it down.
I hope this may have helped you,
Tom
Oct 03, 2009 | Dryers
Dryer turns on when botton held down
Motor has a "Run" winding centrifugal switch that may need to be replaced. Start button energizes the starter winding but when the "run" switch fails the motor won't keep running. Switch is easily replaced without taking motor apart.
Aug 12, 2009 | Kenmore Dryers
Drum doesn't turn, start switch turns dryer on when held on but dryer shuts off as soon as start switch is released.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Dec 02, 2008 | Dryers
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryer model DBXR463. Power is on btu when you turn the start switch there is a humming and the tumbler does not move. Yep, same problem.  Dryer is 4 years old, turn on and get loud hum, no tumbler...
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 28, 2008 | GE DBXR463EBWW Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
121 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
