Question about Intermatic & Indoor/Outdoor Rain Tight Timer
My T101 mechanical turns on manually but not by itself. The gears are no longer moving and the dial no longer changes time. how can i fix it?
Buy new 125V clock motor
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
Or buy new T101 timer and swap out insides without changing box
Posted on Sep 23, 2010
How do I set T101 intermatic T101 timer to 7:30 PM
PROGRAMMING INSTRUCTIONS 1. TO SET "ON" AND "OFF" TIMES: Hold trippers against edge of CLOCKDIAL, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A. 2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
http://www.intermatic.com/-/media/inriver/10162-9164.ashx/T101-Instructions-EN
Mar 23, 2017 | Intermatic Hardware & Accessories
Apparently, the spring under the timer dial on my 4001 timer has been broken and the timer will no longer trip the trippers. Can this be fixed? It is a nearly-new unit and I like it.
Open following link for Paragon resources:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Individual parts are not sold except for X2772 tripper.
Move the manual override lever back and forth and see if load turns on-off.
Watch if on-and-off trippers are moving override lever back and forth, to see if problem is a worn tripper instead of broken spring.
Replacement 4001-00 timers are sold, even though Paragon is no longer making timers except defrost timers.
http://www.mdappliance.com/RBS-4001-00.html?mv_pc=00015
Replacement timer is Intermatic T101
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jun 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
My timer manual switch works,it turns the outside lights on and off. However the automatic dial,even when plled out and set to time to operate does not work.What 's going on? Isit me?
The two tabs are for On ad OFF.
One is slightly longer than the other. If the OFF tab is in the ON location, it won't work, it'll just click past the time and not flip the paddle to ON.
Try this, turn the dial (NOT pulled out) around slowly and see if it flips the paddle to ON. Keep turning it, slowly, and see if it flips to OFF.
If it works while you're "helping it" then it should work automatically. If it doesn't, maybe the gear is damaged and it can't move past a certain point.
Does the time move? Do you hear the motor running? I've seen the motors go bad. The manual flipping will work then, but the motor isn't running the clock around.
Jan 30, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
My t1004r timer does not run any more. The manual switch still works. The problem may be due to rain getting inside. Does the whole unit needs to be changed out?
If manual override works, then timer is basically sound.
1) If dial does not rotate, then replace clock motor: T104 timer uses 240Volt clock motor. T101 and T103 use 125Volt clock motor
2) If dial rotates, but trippers are missing or trippers are worn down and no longer click on-off lever, then buy new trippers.
T100 series trippers and clocks are shown following link:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
3) If you have different timer than T101-103-104, then add a comment.
4) Clock motors are located on back of mechanism.
Mechanism snaps out with thumb spring located top inside box.
Clocks have identifying numbers: google search for that clock number if different that shown above.
5) If you buy new timer, then specify T104R.
R suffix is for raintight box.
6) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | Intermatic T104 24h 208-277v Mechanical...
How do I reset the time needle on my intermatic modle t101 The screw was loose and the needle move so
T101 Intermatic is 120Volt electro-mechanical timer
Silver pointer is located at 6:00 position.
Tighten the center screw with star screwdriver
Lift and rotate yellow dial until current time lines up with silver pointer.
How electro-mechanical timers work:
Place ON-OFF trippers on dial.
Trippers rotate around with passing time.
Trippers encounter on-off lever.
OFF tripper clicks lever one direction.
ON tripper clicks lever other direction.
Manual override lever clicks back and forth each time on-off lever is clicked.
How to wire T101:
Nov 16, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
I have a T101 Mechanical timer that isn't working properly. The clock seems to be working fine, and if you turn it to manual, the lights come on. However, the lights do not turn on automatically. Any...
First be sure dial is actually turning. Are the trippers tight on the dial? Sometimes when the gears and motors are going bad, the dial will turn until it gets to the tripper, then stops. It doesn't have enough forct to trip the switch. You can buy just a motor if that's the problem. www.intermatic.com
Aug 18, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
T101 clock runs but doesn't turn on some days, other days it does
Check the 'tripper' on the dial and give the contact a good look. These have been known to break and also move out of the tripper path. If it's not that then you could have an intermittent connection going on you. Give all connections a good check.
Sep 07, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Trippers do not work and jam time wheel
I'm having this same problem. Anyone have a solution for this?
Apr 26, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
109 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
