Question about Yamaha Boating
I have a 9.9 1993 4 stroke Yamaha outboard long shaft that leaks a small amount of oil out the 1/8 inch hole in the back of the motor, even when not running. It overheated once and I had the impeller replaced and it started leaking after that. The motor runs good and has less than 50 hours on it. It is a T9.9 EXHR, sn-785926.
4 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: i have a yamaha 2
On the tachometer back you have secured a wire thread just like the one from the brakes of a bicycle. The other end of the wire is secure to the engine. This wire complete, need to be replaced.
As a test first disconnect it from the tachometer and see if ok if not then the problem is with tachometer.
Posted on Oct 03, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a 1993 Yamaha 4 stroke outboard long shaft
the problem should be from the oil seal, the oil seal must have slacked or worn out, so it cannot withhold the oil and that's why it is dripping.
Trace where the oil is dripping from, loose that part and you will see what's making it leak, seal that area/part up or replace whatsoever oil seal that is slack or that is making it leak.
You might be needing the help of a repair man if you don't know how to come about this.
Good luck.
Posted on Oct 18, 2010
goldbill
  • 184 Answers
SOURCE: Johnson 235HP Outboard - oil leaking from bottom leg - dark black so picking it is the two stroke oil
most 2 stroke motors will not burn all the oil in the mix and that unburned oil coats the exhaust leg and leaks out the thru hub exhaust and parting line of the lower to the housing. so keep some windex handy and clean it up.
Posted on Oct 11, 2012
Testimonial: "Thanks for your help William. I am new to two stroke outboards so your advice answered a few of my concerns - I have now got my hands on the manual for this motor and are digesting alot more information - they are complicated! Thank you"
I have a 2003 yamaha 40 hp four stroke outboard, this year started up seemed to run great after about 25 minutes i shut it down an hour later checked oil crankcase full of water
water in the engine crank case oil --major seal or corrosion problem in the motor
water in the leg gear box --
pump seal on the drive shaft
Jun 01, 2017 | Yamaha Boating
Where is the oil filter located on a 2004 Yamaha outboard two stroke motor
Some links including a video of how to change the filter. In such questions horsepower is useful along with year :>) Oil filters would only be on a 4 stroke though to protect the engine oil. Your two stoke doesn't have filters in the lower unit. There may be a strainer in the two stroke oil tank.
check page 31 here
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-03_1415.pdf
Google
year make HP manual
http://www.bing.com/search?q=oil+filter+located+on+a+2004+Yamaha+outboard+two+stroke+motor&form=PRHPR1&src=IE11TR&pc=EUPP_HRTS
Jul 04, 2016 | Yamaha Yamalube Outboard Oil Change Kit...
I just bought a 1998 5hp 2-stroke Johnsons motor and was just wondering what's is the best mix for it?
While the two cycle oil has it on the back of the bottle but with my 1998 I would pure a bottle in it or depin on how much gas you got I like my gas kind of a blue tint
Feb 08, 2015 | Boating
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
For a yamaha outboard motor 2 stroke , how much oil would be added to 12 litres of fuel
50 litres petrol:1 litre Outboard TCW3 OIl
100litres petrol:1 litre Outboard TCW3
@ 50:1 You Would Put 240Mls Oil In 12 Litres Petrol
@ 100:1 You Woul Put 120Mls Oil In 12 Litres Petrol
Mar 12, 2013 | Boating
How much 2 stroke oil do I need to add to 1 litre of petrol to achieve a rotio of 40:1
40:1, means 40 parts petrol to 1 part oil. So it's (1 litre-1000ml) divided by 40= 25 ml of oil. Even if you had an odd amount of fuel, Say 7.5 litre's-7500ml 7500 divided by 40 = 187.5ml of oil.
Sep 01, 2010 | Light Outboard Motor Boat Bass Fishing...
Lower unit oil
On the lower side of the gearbox,below the line of the prop shaft,you will see a screw that is about10-15mm across.This is the drain for the g/box oil.If you look above that screw about 150mm(6 inches),you will see another screw the same.It may even be marked 'oil level'.Remove them both.
Checked the drained oil is not milky.It's a sign of water and the propshaft seal would need to be replaced.
The oil bottle you buy will have a tapered nozzle.You must fill the g/box from the LOWER hole by sqeezing the bottle.When it comes out of the UPPER hole,the g/box is filled.Quickly put the lower screw back in first,and then the upper screw.Done.
Before you refill the g/box,check the washer/seal on the screws and make sure they are still good. Hope this helps
Jul 09, 2010 | Boating
I have an ancient yamaha 4hp outboard two stroke.... it has a dammaged aluminum housing on the leg on the left hand side directly below the motor. Cant tell what might have used to be there....Can see the...
sounds like this is the access hole to allow you to reach the clamp which hold the gear selector rods together, even if you dont have gears this hatch was incorporated in the caseing you could cver this hole up without causing any problems but dont make a permenant fix as you may need to use this access hole at sometime.
Jun 04, 2010 | 1985 Yamaha XJ 700 X Maxim
What type of petrol is needed for a yamaha outboard motor horsepower 8?
reg unleaded gas.
You haven't specified as to its year of manufacture, so if its older, as in a 2 stroke, it'll be a mix of gas and outboard oil.
If its a newer model, a 4 stroke, it'll be injected(Gas and oil seperate)
If you are totally unsure, Consult your owners manual and if you have none, then any Yamaha dealer can use the serial # off the motor to establish any specs on it for you.
Happy boating.
Oct 04, 2009 | Boating
Boating Logo
99 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
