Question about Sanyo Vpc-s1070w Digital Camera
The lenz is stuck out and it won't go back in
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 10, 2010
How can i get manual fo this inverter?
There doesn't appear to be any documentation on the Lenze website for this model, but this is their contact page and they should be able to e-mail you a manual for the inverter.
http://www.lenze.com/lenze.com_en_active/0080_kontakt/Com_Kontakt.com.jsp;jsessionid=C4ADFA03DE6CD97BD3B53ED22AFDDB3D
Hope this helps!
Apr 16, 2011 | Lenze AC Tech Lenze 8100 AC Drive Inverter
We need user manual of Lenze ac 7800 ., if any one could help us with the same ., contact on nmbabrakar@yahoo.com
http://src.lenze.com/lenze-bibliothek/Lenze-Archiv/AA%20-%20Inverter%20Drives/7xxx/TB_7811-7818_EN.pdf
Mar 13, 2010 | Lenze AC Tech Lenze 8100 AC Drive Inverter
Keb inverter and lenze inverter
I would have to say that you will not be able to swap the KEB inverters with the Lenze inverters or the Lenze inverters with the KEB inverters.
The PLC ProfiBus system would most likely need to be re-programmed for the change.
Mar 11, 2010 | Inverter KEB COMBIVERT F5
Lens is stuck and camera will not turn on.
there is a problum in your lenze block (optical assy) this problum is not remove at home so please go to your nearst sony service centre & repair the lenze block because no the child parts are avalable
Feb 12, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Samsung S760 Digital Camera - Not turning on and lenz stuck out.
Yes you are correct lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Jan 30, 2009 | Samsung S760 Digital Camera
Lenz stuck out
If the lens mechanism has been damaged or is sticking from foreign material around the lens housing it will shut down when you try to power on. Once in a while you can try to assist the lens by placing gentle pressure against it when you power on and the lens may retract. This will most likely not fix the problem but it may give you a better idea if the mechanism is damaged or not.
Sep 20, 2008 | Kodak Easyshare M753 Digital Camera
Sanyo Vpc-s1070w Digital Camera Logo
24 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
