Question about Estate Washing Machines
I have an Estate model TAWX700JQ1 washer and it won't drain the water out or spin.
Had the same issue. I replaced the timer part no 3953146 and that solved my problem.
Posted on Oct 19, 2010
2 Suggested Answers
  • 552 Answers
SOURCE: my wirlpool estate washer
Very common issue on this unit. The lid switch assembly is broken and need to be replaced. The repair is straight forward a DIY'er can make this repair friend
Posted on Apr 22, 2011
HOW TO TEST WASHER TIMER MODEL# TAWX700JQ1
sounds like pumps blocked prob a sock or something small like hair clip
Aug 25, 2014 | Estate Washing Machines
Whirlpool Estate washer ETW4400WQ1 spins but won't drain
Sounds like either the water pump or the program selector, probably the water pump though
Apr 18, 2014 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My wirlpool estate washer model TAWX700JQ1 will not spin or agitate but does fill with water
Apr 22, 2011 | Washing Machines
Whirlpool washer machine model TAWX700JQ1 will wash cycle and will not go to next cycle and will not drain the water
I had the same problem, I replaced the timer part no 3953146 and that solved the problem.
Jun 12, 2010 | Whirlpool Washing Machines
My Estate washer will not drain.
Hey Don, If you removed the cabinet to get to your pump, you had to unplug the wire that connects to your lid switch. Did you make sure to plug the lid switch plug back into it's plug-in on top of your cabinet under control panel when you re-installed the cabinet. Your washer won't spin or pump water if this is the case. I'd check that first, then check the lid switch itself for proper operation. Happy to help, Tim. please don't forget to rate my help. Thanks.
Jun 28, 2009 | Estate TAWX700JQ Top Load Washer
Wont drain or spin is lock up
does not spin all water out, towels are still wet, not overloading, could it be the timer?
Mar 01, 2009 | Estate ETW4400VQ Top Load Washer
My washer will fill up and drain, but it wont agitate or spin
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 11, 2008 | Estate TAWX700JQ Top Load Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
340 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
