Question about Kenmore Whispertone 29512 Vacuum
Put on a new beater brush belt that I bought from Sears as detailed on the plate on the vacuum. It immediately snapped. Is there a diagram for the routing for the belt (there is a drive spindle and a tensioner)? Thanks.
  • 377 Answers
I would first check to see if the beater brush is turning freely. You should be able to turn it by hand. If you can not, remove it from the vacuum and clean any debris on the brush and especially on the ends that hold it in place. Some WD40 on the end pieces might help as well. There is usually a belt diagram on the plastic case of the vacuum where the belt itself is found. Best of luck.
Posted on Sep 10, 2010
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    Reinstalling beater bar... making a noise like its not in the correct slot.
    Getting the sole plate back on correctly and the beater brush in the correct slot should help. The clucth is engaging and keeping the motor from overheating is the noise you are hearing.
    bearings in the brushroll might be siezing. If you start snapping belts, change the brushroll. the roller brush that most likely needs to be cleaned,clean the hair from the brush and under the belt and make sure the bar is positioned in the vacuum properly and turns easily. Your problem could be the clutch unit what has probably happened is either the clutch plates are warn, or the 3 balls in the clutch have warn a large grove in there fixing plate or the plastic hub that the brush roller to clutch belts runs on has melted this hub melting is the most common of all clutch faults.
    There are no spares available for repairing the clutch other than the motor to clutch belt & the clutch to brush belt. Here is a diagram to help you
    Nov 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Beater does not work.
    Not knowing what type of vacuum you have does not make it easy. However, usually caused by a broken belt or the fact that the beater brush is bound up by debris either being on the beater or having accumulated at the ends of the beater where the brush is supposed to spin on the end plates. After checking the belt I would remove the beater brush, clean it very good and put some WD40 on the ends of the axle of the beater brush and make sure it spins freely on the holding plates.
    Sep 08, 2010 | Vacuums
    Brush doesn't turn when on carpet
    This sounds like the beater brush drive belt is either slipping, off the pulley, or broken. Unplug the vac, turn the unit over, and remove the bottom plate which may require you take out some screws.
    Depending on your model, you will see a belt on one side or the other of the pulley and beater brush assembly. It's usually best to replace the belt, especially if the vac is over a year old. This is also a good time to clean any debris from the brush and the immediate area.
    If you aren't comfortable doing this sort of work, just about any vacuum cleaner or appliance repair shop can handle this if you have one in your vicinity. Shop around.
    Dec 25, 2009 | Bissell 3920 Bagless Upright Vacuum
    How to change belt on sears vacuum cleaner
    I believe you turn the vac over so the beater bar (brush) is facing up.
    Depending on the age there maybe screws or tabs that hold the plate on to the bottom of the unit. Remove those and the plate. That should expose the bar, belt and motor pulley. If the beater bar doesn't pop out when the bottom plate is removed, pull it out and remove from belt. (Pay attention to how the bar was inserted. It may have a pentagonal shape and only fit properly when inserted a certain way.
    Now is a good time to clean the beater bar.
    Replace with correct size belt and reassemble in reverse order.
    Hope this helps.
    If so, please rate me.
    Thanks,
    Matt
    Sep 14, 2009 | Kenmore Vacuums
    The agitator on my kenmore progressive vacuum won't keep going. It keeps stopping while vacuuming.
    This sounds like the belt that drives the beater bar on the vacuum. The beater bar bearings and brushes could be plugged with debris and/or the belt is simply worn out and needs to be replaced. Unplug the vacuum, turn it over and look for clogging.
    If you can't see any, then you may need to remove the bottom plate of the vacuum and clean out and/or replace the drive belt and clean the area. These belts and other components are usually available at Sears Hardware or main stores. Make sure you get the correct belt for your vacuum.
    If the beater bar brushes are substantially worn, it would also be a good idea to replace the beater bar as well. These parts wear out after a few years. Try to work on the unit in a location that is well ventilated and the debris doesn't make a mess inside your house.
    Apr 27, 2009 | Vacuums
    Dyson vacuum cleaner-brush bar is frozen
    Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
    However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
    Apr 05, 2009 | Dyson DC14 All floors Bagless Upright...
    No suction
    you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
    Nov 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
    Change Belt
    Turn the vac. over, remove the bottom plate covering the brush roll, then on the bottom of the top cover, on each side there should be 2 slots when you can put a flat blade scredriver, pry up to release the tabs holding the cover on. The know will come off also when you do this, just put it back on when the put the cover back on. Put the belt on the brush roll and feed it thru the opening and stretch to put over the motor shaft. The top cover, push down to lock it.
    Dec 23, 2007 | Vacuums
    Vacuums Logo
    47 people viewed this question
    Top Kenmore Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
