Question about Technics Audio Players & Recorders
A few weeks ago I sent in a question and paid the $6.00 but haven't received a response. I have a Technics SL-QD33 turntable that will play an album but only for about 5 seconds regardless of where you place the stylus. I've also changed the stylus due to having a damaged one.
    Brigadier General:
  • 3,301 Answers
Not to be a smart a$$ but I have one too,, and I got a new needle and it was not cut right,, so I got another one and it plays great now,, I did check the weight adjustment at the rear of the arm and it was a little shy of what was needed, a half turn put it back in place and I was off and running, sorry you didn't get the paid for advice,, But this is a freebie ,, good luck
Posted on Sep 10, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Removing the platter to oil the motor shaft
hi .... get any object ( like hammer, or handle or wood) tap slight on the middle spindle of your turntable until become loose,...
May 28, 2009 | Technics SL-1200MK2 Turntable
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Nov 05, 2007 | Technics SL-BD22 Turntable
94 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
