Question about Symbol MC3090
"Find WLANs" option does not show the wireless router used in our office. We are using the Motorola Scanner model MC3090. Any help in this regard is appreciated.
2 Suggested Answers
  • 72 Answers
SOURCE: battery problem, MC3090
It sounds like it is. Fully charge the device to 100% and allow it to drain fully until it completely powers off, then recharge to 100% again while the device is powered off (usually takes 2 hours +) if that doesn't alleviate the 'memory effect' then the battery has reached the end of it's useful life and should be replaced. Good luck!
Posted on Nov 10, 2009
How to change host on mc9090
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Apr 07, 2015 | Symbol Motorola MC9090 Mobile Computer
MC9190-G Wireless not connecting
Hi I have met the same problem, did you fix it finally?
Could you give some suggestion about this?
Mar 27, 2013 | Zebra Computers & Internet
How do I connect my N410 symbol bar code scanner (running on Windows Mobile) to my wireless router?
If you have a model with Wireless functionality, can you use the Fusion application to manage your wireless connection. There should be an icon in the right corner.
You need to find out which authentication and encryption is used on the specific WLAN.
Then launch through clicking on the Fusion icon the Find WLANs dialog and follow the process of creating of new WLAN Profile.
Feb 28, 2010 | Zebra Symbol Technologies MC909X-G Series...
How to setup wireless connection
Hello prabap. To set up a wireless connection on your MC3090, it is quite similar to doing so on a Windows-based PC. Just use the stylus to select the WiFi icon on the bottom-right of the screen and select 'properties', 'options', 'configuration', or 'connect to/set up a wireless network'. Which one you'll see depends on your OS. Just follow the instructions in the menu, input your desired connection information like the network name, password (if any), and any other information that you may need to connect to your wireless. It is important to make sure you have all the details of your network for it to connect properly. In essence: just approach it like you're setting up a wireless connection on your PC and you can't miss. If you need more help, please feel free to send me a message or email. I hope this helps. Good luck!
Jan 02, 2010 | Symbol MC3090 Wireless Barcode Scanner
MC3090 is having trouble scanning 2D labels. It
No...check the printer that is creating the 2D code. It's probably the culprit. Make sure the head is perfect and the 2D code is big enough. The 2D version of the MC3090 doesn't read small 2D codes.
If it still doesn't work, contact your dealer or the Moto Help Desk at 1-800-653-5350
Oct 22, 2009 | Symbol Motorola MC3090 Handheld Computer
Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
Aug 26, 2009 | Symbol Motorola MC3090 Handheld Computer
MC9090G "Find WLANs" got error Scan Error. Adapter Unavailable
I had the same problem and I did a cold boot and the wireless icon showed on on the 'desktop' and I was able to use it again.
to do a cold boot, turn off the unit, remove the battery, pull the trigger and hold the power button for 5 seconds or so, and put the battery back in.
Jan 14, 2009 | Zebra Symbol Technologies MC909X-G Series...
No wireless connection
Go to Parental Control after logging into 192.168.10.1. Then make sure you have allowed the MAC addresses of the wireless clients ( machines). Reboot the router one after making any changes.
Good Luck
Dec 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Symbol MC3090 Logo
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
