Question about Kenmore Refrigerators
I have a model 106 kenmore refrigerator with an ice maker. The ice maker has worked for 20 plus years and just quit working. Is there anything I can troubleshoot to see if I can get it working again.
    President:
  • 1,218 Answers
Good day,
If the freezer section is at it's normal temperature (cannot be above 10 degrees) then follow these steps. It. will get you there.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Sep 10, 2010
  • John Hall Sep 10, 2010
    P.S. If it is old enough. It is possible the white plastic gear under the front cover has stripped a tooth. Unsnap the front cover and inspect the gear. Do that first.
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Dec 30, 2009 | Kenmore Refrigerators
Describe your kenmore 106 53502300 Problem ICE MAKER NOT WORKING.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
tui
Nov 10, 2009 | Frigidaire PLRS267ZAB Side by Side...
Model # for refr. 106 50037000. module # for ice maker 106 626636. it quite.i felt the ice froze in the maker but it didnt flip it out. i took the maker out let the ice melt.put maker back in , it worked...
Sound the the bi-metal is starting to fail or the freeezer is not getting cold enough. If you put a thermometer into the freezer and it gets below 8 degrees and does not harverst then your looking at the ice maker which is a Whirlpool part number 4317943. This a kit will replace most of those style ice makers. It is the quickest and easiest way to solve your problem. You should be able to get it for between $85 to $160 depending on where you live and who you buy it from.
Dec 05, 2008 | Refrigerators
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Red light blinking inside freezer compartment of Kenmor Elite, model 106 52603100. Ice maker has quit working. Is this blinking light a code?
The light may be telling you that the temperature is not cold enough to operate the icemaker.
You may have a bad defrost timer, heater or thermostat. If you have an ice bucket then it may ot be seated properly.
Stargazer
Mar 15, 2008 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
