Question about Makita 6019DWE 3/8 Cordless Drill Keyless Chuck Rev 7.2v 600 Rpm
Broken drill chuck on model a742b mag drill - Makita 6019DWE 3/8 Cordless Drill Keyless Chuck Rev 7.2v 600 Rpm
3 Suggested Answers
  • 5 Answers
SOURCE: Drill chuck is frozen
You may try to put a thick soft metal pipe (aluminium or copper) over the drill bit (longer than the bit itself by ~10 mm) so it will touch the chuck's jaws, then GENTLY hit the other end of the pipe with a hammer several times, holding the pipe a bit askew, thus trying to disengage the jaws from the lock in their thread, and try to loosen the chuck after each series of hits. Just be careful with your fingers, and better hold the drill by the chuck while hammering it - so the hits won't go to the transmission unit (sorry for description - hope it's understandable, if not - ask for clafication from me)
Posted on Jun 08, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have an older (green in color) Makita 7.2 volt
go to the tip section and I left detailed instructions on how to do this, or go into my profile and you will find them there, it is not really that hard.
Posted on Oct 29, 2010
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
    Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
    Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
    Keyless chuck drill just spins
    Some times the selector on top get gummed up with dust, it just needs cleaning. You were right to put it into 1st gear to remove the chuck with a big allen key, you get more resistance in the gears.
    May 30, 2012 | Makita Drills
    Snapped sds plus drill bit off in chuck. how do i take it apart to get it out i have taken chuck covers off but cant get hold of broken bit with long nose pliers
    dont know the exact model you have but if there is a retaining ring on the spindle I would remove it and the corresponding parts and then you can put a small screwdriver in the slot on the side to start moving the bit. If you need more help give me the model number and I will see what I can do
    Jan 18, 2011 | Bosch Drills
    Skil 3/8 Hammer drill #6425 chuck ring broken in half
    get a new chuck - thread is a 3/8-24 left hand thread
    Oct 22, 2009 | Skil Drills
    Got a broken drill chuck i cant get off (Dewalt)
    first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
    Jul 02, 2009 | Dewalt 18 Volt Compact Drill Kit
    Chuck Shaft becoming detached from drill motor
    Many times there is a allen head screw in the center of the chuck bottom that screws into the shaft of the drill if this screw is missing the chuck will unscrew off the shaft. Many times depending on the size of the drill it is a 10/32 allen screw about 3/4" long that screws into the shaft thru the open end of the chuck.. Sometimes it is a Left handed thread.Check the illustrated parts breakdown for the drill to get the correct part. Hope that helps
    Mar 02, 2017 | Black & Decker Drills
    Keyless chuck problem
    I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
    Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
    Makita 6019DWE 3/8 Cordless Drill Keyless Chuck Rev 7.2v 600 Rpm Logo
    77 people viewed this question
    Top Makita Drills Experts
    epangan29
    John Trevino
    Are you a Makita Drill Expert? Answer questions, earn points and help others
