Question about Fossil Watches
How do I clean the white watch band on the Stella watch?
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
Bwhat do i clean white resin watch band
Hello, here is an article with tips to clean watch bands, and according to several of the comments, the process was successful on several Gucci and Michael Kors watches as well.
May 10, 2014 | Gucci Watches
Where to buy white polyurethane watch band
This band you will easily get on Amazon, Ebay, Etsy and Discountedwatches247 etc. The Discountedwatches247.com provides beautiful watches and watch bands in discounted price and lots of designs and colors available. You can purchase a cute ladies watch for function, causal watch or a stylish digital watch and many more. These Cheap watches are good quality watches with the latest design and style.
Jan 27, 2014 | Kenneth Cole Kc2461 New York WomenS Kc2461...
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
Feb 02, 2012 | Fossil Stella Topring Watch
My fossil Stella clear watchband needs cleaning how do you get this clean?
Unfortunately it is a part of wear and tear of the that material. The longer you used it with an acidic sweat it will continue to discolor. Try washing it with mild soap and water after every used. That's also my problem before with my watch.
May 08, 2011 | Watches
How do i take a link out of my stella watch?
mcdevito75 here, Genearlly removeing the bands links are more common with Mens watches but some womans watches also have this option, the links are held together with pins which require a link pin remover tool so these pins don"t get bent. Best Bet is to look for a small watch repair shop in your araea and have them remove a link or two, also hold onto these removed links in case you need them again.
Feb 11, 2011 | Fossil Stella Topring Watch
I have a calumet watch, and the band is getting dirty. Is there a way to clean the band?
Polyurethane Band
Polyurethane Bands, which are made of soft plastic, may turn hard after 2-3 year's use. Colour fading can also be seen.
If bands are kept wet and in highly humid locations or are exposed to sunlight for a long time, the deterioration of the bands may be accelerated in a relatively short period and some cracks may appear on the band surface. (This is called 'hydrolytic cleavage of polyurethane')
Kindly pay attention to the condition of polyurethane bands, which are often worn in such occasions as marine sports/outdoor activities
  • We recommend immediate exchange when your polyurethane band loses elasticity or develops cracks.
  • Semi-transparent/white/fair coloured polyurethane band may turn a different colour due to light/stain ( or sometimes may absorb colours from other materials). In addition, polyurethane bands have many small holes on the surface, which easily catch and hold stains/other different colour material. Thus it is rather tough to entirely clean polyurethane bands. Kindly replace current polyurethane band with a new one when you find extreme discolouration.
  • There exist some sorts of stains (like oil/cosmetics), which cannot be removed off. Smoking cigarette/long time use may turn the colour yellowish.
CAUTION!
Do not use solvent/chemicals (benzene/thinner/breach) for band/bracelet cleaning!
Aug 24, 2010 | Alessi Watches
White band turned yellow
mcdevito75 here, Sounds like the chlorine in the pool water dis-colored the band, not to mention, possibley the watches mechanism also. Look for a small watch repair shop in your area for a new band and possible remedy for the water inside the watch.
Jul 07, 2010 | Adidas Adibot ADH1325 Watch for Women
What can I use to clean my baby-g cool and tough white band?
Try using goo gone it might work I have seen replacement parts at www.casiosalesandservice.com you call call them toll free to see if they have the replacement parts.
Feb 13, 2010 | Casio Baby-G BG370S-4V Wrist Watch
Discolored white nautica watch band
Jan 25, 2009 | Nautica N07574 Wrist Watch
Watches Logo
214 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
