Question about Wolf Range Kitchen Ranges
Igniters will not shut off Onn a the time.
  • 944 Answers
Ignitors are prone to defective.They go bad when use for long time.Check proper voltage going to the ignitor.Use ohm-meter to test it.Replace it if it is defective ignitors cost very less.Remove the screws to change the ignitor.
Remove the burners and clean it perfectly.Dry the burners using hair dryer and remove the parts and clean everything perfectly.
Knob switch could be also could be problem,small dust particles will block the flow of current to bypass switch.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 10, 2010
I have a duraband ht395 reciever and need the universal onn remote model ona12av058 code.. All the ones in the manual do not work? Anyone know this?
[PDF]Instructions - ONN Universal Remote Support
myonnremote.com/.../ONB13AV004%20Manual%20Version01.pdf
Mar 28, 2014 - will retain the codes you have programmed for up .... TV/DVD Combo, you might need to set up one ... Point the remote at the audio receiver,.
Faq - ONN Universal Remote Support
myonnremote.com/onn-faq.asp
How do I manually enter codes for my ONN Universal Remote? ... (You haveapproximately two seconds after the device shuts off or begins playing to lock-in the code.) ... so if you need to start the search again, it will pick up where it last left off.Missing: duraband ‎ht395 ‎reciever
RC: Durabrand codes one for all (Page 1 of 2) - Remote Central
https://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?...
May 4, 2006 - 15 posts - ‎9 authors
Jan 25, 2016 | Televison & Video
What is the website address for ONN electronics?
onn electronics is a generic brand for walmart shops
I typed in onn electronics on the net and there are pages but the walmart has the agencies for the onn products
talk with the tech guys in walmart for the item you requie.
Apr 23, 2015 | Audio Players & Recorders
Furnace blower runs for a minute then shutdowns- no heat
If the flame does not come on it could be the igniter needs replacing. Some times if everything is set to go but if the flame does not light up then it automatically shuts down again. It is common to have to replace igniters.
Apr 17, 2015 | Heating & Cooling
Constant clicking sound everything is working fine. How to get the noise to stop
Shut off the power to the range. It sounds like the igniters got wet. If the clicking sound is still there after you put the power back on, light all the burners to dry out the igniters.
Sep 21, 2011 | Amana AGR5835QDS Gas Kitchen Range
Top range works oven does not. you can set it but never comes on, there is no gas smell from the oven either. I checked the oven gas shut off and that is in the open position.
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface igniters work, but the oven does not, the problem is usually not a gas related issue. It can be a control board issue, or weak or failed oven igniters. Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, or no ignition, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
If you have any questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Jun 16, 2010 | GE 30" Freestanding Gas Range - White
Procedure onn timing belt replacement for 1995
Go to my profile page and check out my Tip and Tricks for timing belt replacement 1.9L, there is an explanation of how to there. Hope this helps, let me know.
Oct 30, 2009 | 1995 Ford Escort
Electronic igniters won't shut off.
Boy, I had a Thermador that used to drive me bats.
The best solution was to clean around the ignitor pin and make sure the orifices closest to the ignitor are not blocked... It made a big difference.
I used a small fine metal bristle brush.. did the trick.
May 30, 2009 | Bosch 36 in. NGT 935 Gas Cooktop
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
My tv turns onn for a few seconds then shuts off
it can be repaired but it would be easier to buy a new tv and cheaper
Oct 22, 2008 | Samsung HCM422W 42" Rear Projection...
Kitchen Ranges Logo
106 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Dan Webster
Dan Webster
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
