Question about Health & Beauty
When turning on joystick control the chair moves but when i stop the lights start to blink and stops moving horn works if i play with the on/off it start to works agian
  • 692 Answers
Fantasy when it stops count the number of flashes. For example it might flash 5 times pause flash 5 times pause etc. This is the flash code and your manual will give you what it means. Being an intermittent problem can be a bear to trouble shoot. It would be nice to know what chair you have and whether Medicare purchased the chair for you. If Medicare purchased the chair then they will pay for most of the repair cost Hope this helps you
Posted on Sep 10, 2010
MY BATTERY INDICATOR LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT CHAIR WILL NOT MOVE
You are in locked mode. try turning the joystick on and pushing the horn twice. or if that did not work try turning the joystick on and pushing gimbal forward until it beeps and then back until it beeps. should be unlocked, scrolling up and down will stop and you can drive.
Jan 27, 2016 | Pride Jazzy Select Elite
THE BATTERY LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT AND CHAIR WILL NOT MOVE
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
When i plug the cable into the joystick control (MK5SOJ+) all the lights around the horn button blink on and off motor wont engage and it won't shut off til pull out the cable do i need a
When you say the power cable I hope you mean the cable that comes from the main control module under the chair. I want to make sure you are not talking about the AC power cable that plugs from the chair to a wall outlet. So if we are on the same page about the cable is the one going from the joystick to the main control module under the chair and all you do is plug it in and the green speed lights start to blink this would indicate the joystick is bad.
Jan 23, 2015 | Invacare Pronto M51 Power Wheelchair
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
The chair is locked. I had this happen a long time ago and I needed to move the joy stick diferent directions to get it unlocked but I do not remember how. It is a Jazzy 1113.
If it is the older VSI controller, turn on chair. as the battery lights scroll, hold the joystick in the (UP) position until you hear a beep. Then immediately place the joystick in the (down) position until you hear a beep. then place the joystick in center position, once you hear the beep for the final time, it should be unlocked.
If you have a Dynamic controller, turn on chair then press the horn button to unlock.
Sep 15, 2011 | Pride Jazzy 1113 ATS Indoor Power...
CHAIR IS CHARGED UP BUT WILL NOT MOVE
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
Feb 05, 2011 | Pride Jazzy 1103 Ultra Standard Power...
The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
May 12, 2010 | Jet 3 Ultra Power Chair
Won't move forward or reverse. all other
Sounds like your joystick is damaged. This chair probably has a PG Drives Technology joystick that serves as both the joystick control and acts as the power control module. If it has been damaged by say, running into a wall or doorway or table, this can be the cause, or if it has gotten moisture inside it, that will hurt it as well. Other possibilities are overloading the chair past its weight capacity or driving it over unstable terrain like sand, gravel, much etc.
Aug 28, 2009 | Pride Mobility Products Health & Beauty
All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Apr 28, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
141 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
