Question about IBM eServer xSeries 3200 (43635FU)
289 DIMM D01 is disabled - IBM eServer xSeries 3200 (43635FU)
How don I cancel my order for #D01-9732438-1855268
You might want to talk to the company you ordered with. We can't help you with this, at least I don't think fixya has an ordering system?
Jan 21, 2015 | Computers & Internet
E2111 SBE LOG DISABLE -DIMM 3
Hi
Two most likely causes for this error are
First: the memory module, DIMM3 has worked its way loose and needs to be reseated firmly in its slot with both catches firmly engaged.
Second: The memory module DIMM 3 has become faulty and needs to replaced.
If reseating the DIMM doesn't work try swapping slots with a module of the same size in a different slot and see if the fault follows the module or goes away. If the fault follows the module, eg to DIMM 1, then it is most likely that the module is faulty.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 30, 2014 | Dell OptiPlex Computers & Internet
Contact us
Fixya is an advice forum for do it yourself inclined people. We have no control or contacts with any vendor or online company.
Mar 18, 2017 | Computers & Internet
How do I get frunt axel out my 2010 triumph thunderbird 1600
This should help. Just use the Regular Download option. This is the complete Service Manual.
http://d01.megashares.com/index.php?d01=tn6fW0Y
Codebynite
Aug 17, 2014 | 2012 Triumph Thunderbird Storm ABS
What is 3-3-2 beep tone meaning
System doeIf there is one DIMM in the system the memory row/bank may be disabled when there is a memory failure. The system will not boot because it has no memory to use. If the DIMM is replaced with one of the exact same type and size, then the system will continue not to boot. BIOS cannot tell when a DIMM has been replaced with one of the exact type and size, therefore BIOS believes it is still the bad DIMM and will not use it.
Here are two possible workarounds:
1. After replacing the defective DIMM, continue to reboot the system until you hear the "no memory" post beep sequence (3-3-3) during POST (no video display). After three (3) incomplete boots, a "062 three consecutive boot failure. Using default CMOS configuration caches are off" error will occur. At this point BIOS will go back to the default settings and begin to use the new DIMM. However, if you have disabled the 3 boot fail count (this setting may not be available in all servers) in Setup, then BIOS will not turn the DIMM row/bank back on.
-=OR=
2. Remove the DIMM. Power on the system until the "no memory" post beep sequence (3-3-3) is heard. The memory row/bank will now be marked as being empty. Power off the system and put a good DIMM back into the system. The memory DIMM row/bank is re-enabled and the system boots normally.
NOTE: If more than one DIMM (or more than one DIMM set) is installed in the server and one memory (or one memory set) row/bank is disabled due to a memory failure then, the user must go into setup and re-enable the row/bank after replacing the bad DIMM.
Additional information
s not boot after replacing memory DIMM Servers
Jun 11, 2014 | IBM Netfinity 5600 8664 Server
289 dimm1 disabled
Go into the Bios or System Setup and see if there are options to enable it. When you turn the computer on, look for which key it says to hit to get into the Bios or System Setup.
Apr 30, 2012 | IBM IntelliStation M Pro 6218 PC Desktop
HOW TO ENABLE 289 DIMM D01 is disabled in server 2008.
terrible question; please add more detail
if your system has a dual CPU socket, perhaps you don't have a second cpu (where more memory banks usually require that second cpu socket to be populated in order to use the dimm slots); doubtful, but there could also be a jumper on your mobo
or maybe look in your BIOS; that's where things are enabled/disabled (i.e. server 2008, afik, doesn't have a way to specifically disable a dimm slot)
the mobo (or system) manual may have guidance for memory installation; e.g. sometimes there's a size or slot population type table (or compatibility; i.e. maybe the memory you are installing is dual rank and the system only takes single, thus it appears that the slot is disabled)
Jan 11, 2011 | IBM eServer xSeries 3200 (43635FU)
E2111 SBE LOG Disable DIMM
The E2111 should also indicate a number after the DIMM, this is the bank of the DIMM it believes to be bad. Depending on your support contract situation, and ability to bring down the machine, reseating the module after cleaning it a bit with some good old 'canned air' may do the trick. Otherwise a module replacement is in order which is typically covered by DELL if you are still under coverage.
Jun 29, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
E2111 SBE log disable DIM2
replace system memory, that indicates on lcd screen #dimm...#. In this case, dimm2.
Mar 05, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
IBM eServer  xSeries  3200 (43635FU) Logo
836 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
