Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Water for steamer but no water flows to make coffee
    President:
  • 1,618 Answers
Remove the screw and shower screen under the brew head, make sure screen is clean, try running the head to see if water flows, if no water remove allen wrench screws, and check spring and valve seat, DO NOT LOSE SPRING AND VALVE. Try running head, if water does not flow, reassemble and descale machine.
Posted on Sep 12, 2010
SOURCE: grinder starts, but doesn't wet coffe before red light comes on
This is a duplicate, here's the answer
I have the same problem but it's easy to fix. Turn the machine off. Open the front panel. Remove the dump box on the side. Pull the grinder unit out.
Look at the thing you just pulled out. You'll see a little ramp going from where everything slides down from the top. That ramp gets damp and the freshly ground coffee starts sticking on it. Take your finger and wipe it off.
Next, is kinda hard to describe. If you put your fingers inside, along the top, center edge of the machine you'll feel a ridge. It's a spring loaded door. Pull it down and clean the grounds out.
Slap it back together and you're good to go. Only takes about a minute when you get the hang of it.
Posted on Feb 08, 2009
EsWorld
  • 1618 Answers
SOURCE: No coffee flows after grinding
Adjust the grind on the machine.
Posted on Feb 26, 2009
SOURCE: no water coming through but steamer working
I have the same problem with Gaggia Baby Dose. there is no water coming through the coffee filter but the steamer is still working. And the shower screen is cleen. Also machine has strange sound.
Posted on Aug 30, 2009
  • 3 Answers
SOURCE: Saeco Aroma Problems
Whenever we had this problem we needed to prime the pump. Turn the machine on and wait for the coffee light to come on. Then push the coffee button and turn the steamer on wide open until water comes through the coffee outlet. I hope that helps. The user manual can be downloaded from the saeco site.
Posted on Jan 02, 2010
EsWorld
  • 1618 Answers
SOURCE: When machine is on, water trickles out of steamer
It sounds like the steam valve assembly needs to be replaced.
Posted on Mar 28, 2010
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Mr Coffee Pump Espresso machine not working. Lights alternately flash between coffee and steam icons, machine makes noise, but coffee does not brew, water does not flow, steam does not come out.
The espresso portion may be clogged with hard water deposits, and the steamer tube with casein. Run a tank of plain white vinegar a couple of times then run a couple of tanks of plain water to flush the vinegar, Open the steam valve while the espresso portion is running and set the steamer pot under the steamer. Don't be surprised if a long white tube of hard white material slides out of the steamer valve. That's the casein, actually a form of organic plastic.
Sep 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Hi, We have just bought a DeLonghi Caffe Treviso. We are not able to get any coffee/liquid to drip out of the filter holder. The problem seems to occur when we are trying to preheat the machine, for...
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Dec 15, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
No water coming through coffee filter. I have descaled twice. You can hear the pump but no water and then it goes quite with no water. I have tried to prime the pump but still does not work. The steamer is...
If you open the steam tap while the pump is running does water come out? if so then you might have a blockage in the coffee solenoid or the bottom of the boiler. Do you hear a 'click' sound when you hit the coffee switch? If not the coffee solenoid may not be operating. The most common cause of the problem you are having though, is scale flaking off the boiler walls causing a blockage where the coffee water comes out. Try hiting the coffee switch, opening the steamer and then if water starts pumping out, close the steamer and see if water starts flowing out the coffee group. Do this without the portafilter (coffee holder) in place.
If you do get water flowing trough the group, try backwashing the machine.
If these things dont help then you should take it to an authorised repairer or open up the boiler yourself if you are a handy person and have access spare parts. Good luck, these machines can make a great espresso when in the right hands and working order.
Dec 01, 2010 | Gaggia Classic Espresso Machine
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
Steamer works but not water comes through coffee, even with no grounds in
there is a relay that is supposed to open a valve to let the hot water flow and the relay is not working. see if your coffee maker is still under warranty and take it for service.
Nov 13, 2009 | Solis Crema SL-90 Espresso Machine
Jura Impressa S9 Steamer trips circuit breaker
Hi
There`s probably an leakage from the steamblock, and the water flows over the contacts. This will short circuit the machine. Contact your dealer or nearest servicepartner and they will fix it with a new water connector.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
283 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
