Question about GE Profile DPSB620ECWW Electric Dryer
PROBLEM: Dryer doesn't always heat. - GE Profile DPSB620ECWW Electric Dryer
  • 1 more comment
  • tinkerhead Sep 10, 2010
    Product: GE DPSB620EC4WW Dryer
    Tests conducted:
    :: Verified 240VAC at outlet.
    :: Heating element works sometimes, and tests fine (no dead short, no open circuit)
    :: Thermal fuse is closed.
    :: Tested thermistors. Inlet measures in the neighborhood of 47kohms (per the schematic inside the back panel), outlet thermistor measures about half of that (which it doesn't say it should on the schematic).
    :: Both thermostats closed at room temperature.
    Parts replaced:
    :: Main circuit board (it was under warranty and everything else seems to check out okay, except output thermistor?)
    My initial problem was cold wet clothes at the end of a cycle. Sometimes you could cycle the power and it would work. Other times you get nothing. I disassembled the entire dryer, checked all electrical components, results above. The only thing I found to be odd was the output thermistor reading. The spec sheet inside the back panel only says that the thermistors should read about 47kohms at 85 degrees or so, doesn't specify there should be a difference between the input and output, however a local applicance tech says that seems fine? After I put in the new mainboard, I turned the dryer on a timed dry (no sensor) high heat – worked fine. We have run 2 loads of clothes through since and it seems when you use the sensor on medium heat, it didn't work. I managed to get that load dry by using high heat for 30 minutes on timed (no sensor) dry.
    I'm out of ideas here. The output thermistor is the only thing I think could possibly be the problem? Does anyone know the correct value for the output thermistor on this dryer at a certain temp (e.g. 85 degrees F)?
    Sorry for the jumbled mess. It was nice and formatted, but looks like it removes all the line breaks... Bottom line is everything seems to be fine, I replaced the main controller board but it doesn't seem to have helped. I suspect the outlet control thermistor, but I am unsure what the resistance should read at room temperature.
    My apologies, meant to say that the inlet thermistor registered in the neighborhood of 78kohms, the outlet was in the 40s. If the values listed on the troubleshooting guide are for both, it would seem the dryer thinks the outlet temperature is very high and may be shutting off the heater coils.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
  • tinkerhead Sep 16, 2010
    This troubleshooting tip doesn't mention thermistors. That was the problem. Outlet thermistor was reading in the 40s kohms. Should have been in the 70s kohms for the temp I was in. I ordered a replacement, swapped it out and I'm drying again. The dryer thought the heat was really high coming out the outlet so it was killing the heat.
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Whirlpool dryer will not heat
Gas or electric? If gas check for flame. If electric check the heater element. Go online and get a replacement. Doesn't really matter which watts you get. Should always run dryer on low setting and let the air do the work not the heat. Check the air vent and clean as necessary. You can save energy by doing loads and then adding wet clothes to dry clothes. Break up the wash load into managable sizes. Let me know.S
Apr 11, 2012 | Dryers
Kenmore gas dryer doesn't always ignite the gas. I have checked all the vents,
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 08, 2011 | Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
Our dryer was working yesterday morning, but later in the day it would continue to run but would not produce any heat to dry the clothes.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 03, 2009 | Whirlpool ET8CHEXSQ Dryer
Fridgidare dryer spins but no heat.
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 02, 2009 | Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
NO HEAT
it could be a bad: heating element or internal temperature switch. but i would turn you circuit breaker in your house off then back on first. sometimes the dual breaker will trip only one side leaving you with a partially functioning machine.
·                                 I like this quote from fixitnow.com
by Samurai Appliance Repair Man
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
Aug 01, 2008 | Whirlpool Dryers
My dryer is not heating
  • I like this quote from fixitnow.com
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
Jul 31, 2008 | Dryers
GE Profile DPSB620ECWW Electric Dryer Logo
145 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
