Question about Maytag Dryers
Stop working,but when you push strat button it makes a humming noise.
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. Also could be a faulty motor.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 11, 2010
Kudi01tj
do you here a hum noise ? trying putting some water in the unit and strat it to see if the motor is running if that works then you have a problem in the fill components there is also a float in the front corner and it might be stuck up
May 24, 2014 | Dishwashers
Whirlpool Dryer Starts fine, but then stops and start button stops working
This is a sign of the Motor failing. The motor is over heating and then wont start again. When the start button is pushed, does it make a humming noise? If so replace drive motor and it will fix it all up!
Apr 24, 2012 | Whirlpool Dryers
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
I put a new fuel pump in my 1989 jeep cherokee now its making a loud humming noise when i strat it and while its running was not doing it at first come from ta fuel tank can you help ......
Not Sure About A Jeep But Sounds Like Your Fuel Pump May Be Going Out But Thats Only When You Have Not Changed The Fuel Filter In A Very Long Time. Because If Your Fuel Filter Is Very Clogged And Your Pump Has Been Fighting To Push Fuel Through It When Your Pump Is Working Harder Than It Should And Then You Change The Filter. The Sudden Change In Force Needed To Get Fuel Through Can Make The Pump Go Out...
Apr 14, 2010 | 1989 Jeep Cherokee
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
HUM NOISE OCCURES WHEN TURNING KNOB TO LEFT BEFORE PUSHING KNOB TO START- STOPS WHEN POINTING TO OFF POSITION - MODEL GYC4000AWW . DRUM DOES NOT TURN
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Oct 12, 2009 | Magic Chef CYG2000AWW Gas Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
