Question about Vacuums
Waring pro wine opener will not charge. green light does not come on
Ihavea shark nv lift-away pro the brush dont spin an the light dont light up it caught a floor vent wean this started . is ther a reseat if so ware is it
Sounds like you broke the brush belt. Easy to replace and most come with a replacement attached somewhere on the vacuum. The light is probably just burned out from the impact
Nov 29, 2014 | Shark Navigator Lift-Away Professional...
Roomba 4106 new battery charged but wont start
see the diodes, resistor, capacitor inside for test.
since the battery is new, the power charger is faulty, power regulator IC is bad.
God bless you
May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
I have an Energizer Model CHDC7 battery charger for AA/AAA batteries. I'm not sure how to use it. Specifically, when batteries are inserted and plugged in, it displays flashing green lights over all...
Nickel-Metal Hydride (NiMH) batteries are usually charged in pairs in consumer chargers. The CHDC7 can charge two or four batteries at a time. Their position in the charger is important (see the link at the end of this note). Each battery has a separate pair of green LEDs. There are no other LEDs on this charger. The LEDs light up to show the state of charge. Flashing means it is charging. Solid means it has reached that level of charge (ie, 1 LED = half charged, 2 LEDs = fully charged). The batteries will get warm but not uncomfortably so. After some practice you will be able to tell if they are getting too hot (which may signal a worn-out battery which should then be replaced). Like all rechargeable batteries, NiMH batteries have a finite life (measured in number of times they've been discharged and recharged). IMHO, they should also be used and charged in matched pairs. I mark them when I take them out of the box and keep them paired in use and in charging for maximum life. Yes, the devices that use 3 batteries are a pain to deal with. LOL. All details can be found on this Energiser data sheet: http://data.energizer.com/PDFs/chdc7_instructions_english.pdf
P.S. The CHDC7 remains open for charging. Closing it for storage is optional but minimizes the space it takes up.
Jul 30, 2011 | Vacuums
Euro-pro iron. red light on. green light blinks on but iron will not heat up. lights do not progress through yellow (does not go past green) purchased from walmart with warranty extention on 12/08. ...
When the green light stops blinking and is solid, the iron is ready for use. Touch the handle and begin using. but as you mentioned that green light is blinking and the iron is not heating then there is definitely a short in wire some where it has to be checked.most probably its the short in the heating coil wire.but if the heating coil wire is proper and not short then your irons heating coil probally went bad its alot cheaper to just buy a new iron .because heating coil costs near to new iron.but still get confirm if its short in wire. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 18, 2010 | Vacuums
My Shark Euro-Pro EP750 has stopped charging. I
Either the battery is not making contact with the charger internals, or the battery itself is at end-of-life.
Feb 02, 2010 | Euro-Pro Shark EP750 Bagless Handheld...
Green light on gets hot no steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ddr
Sep 06, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
369 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
