Question about Cycling
My Schwinn High Timber has developed a thump when I pedal under load. The thump occurs when either pedal gets to the bottom. When coasting or pedaling not under load, there is no thump. There is no thump when reverse pedaling. Any suggestions? Thanks
  • 843 Answers
Sounds like one or both of the crank arms are loose. The crank arms are the aluminum bars about 10 inches long that the pedals are attached to. They are attached to the bottom bracket spindle by way of a square hole that is tapered so as to fit tightly as the nut on the end of the spindle is tightened. You can test this by trying to move the two crank arms in opposing directions. To tighten, you probably have to remove a dust cap to get at the nut. But if you don't have a wrench to fit, this is a 1 minute fix that any bike shop would probably do for you for free. To see this, Google images for --- bottom bracket crank arms --- good luck vote if you found this helpful Al K
Posted on Sep 10, 2010
What is the shape of the handle bars on the Schwinn High Timber Girl's bike?
These are certainly not racing style bars; but the modern, hybrid riser handlebar.
They will not sweep back toward the rider as much as a beach cruiser handlebar; but could be adjusted rearward to come closer to the rider. They definitely allow for a more upright riding position than many other handlebars though.10_19_2012_7_26_19_pm.jpg
Oct 19, 2012 | Schwinn High Timber Girls' Mountain Bike...
Thumping sound when coasting in ford escape awd
I suspect there will be something loose in a CV joint, under load it will be held in place but when it is not under load it flaps around causing the thumping. You should be able to identify which side of the vehicle it is coming from then a mechanic should see it ASAP because if it lets go completely it will not only be dangerous and stop the vehicle from going anywhere it will be very expensive to fix the colateral damage.
Jun 03, 2012 | 2006 Ford Escape XLT
Steering seems to go stiff at times and seems to have a mind of its own
The headset may have too much load on it or the bearings need service.
http://www.sheldonbrown.com/handsup.html
Search Engine: "how to adjust a threadless headset" for videos
Jun 25, 2011 | Schwinn Bikes 26 Mens High Timber 26 FS...
It doesn't roll smooth there's a grinding when it's coasting and it's worse when im pedaling. What the problem. I just bought it too. How do I fix it?
Diagnosis first.
I'd advise you to apply your eyes and ears to the problem, paying particular attention to parts that move. A coasting noise is tire rub somewhere or some really bad bearings.
Pedaling adds the chain, pedals and crank bearings to the mix.
Feb 16, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Noise once every revolution
You either have a bad bearing in one of your wheels or in your bottom bracket ( where the crank is connected ) It could also be a pit in the bottom bracket where the bearings ride. If this thump occurs about the same spot on your cranking revolutions I would say it is a pit in that bottom bracket. If it were the bearings themselves that were worn the thump would be more random. The first thing to do would be to remove the chain from the crank. Then crank the pedals using your hands and see if you can feel that thump or vibration with your hands. If you feel it there then replace the bottom bracket or get new bearings. If this does not solve your problem then check the wheel bearings. Just take the wheels off and spin them while holding onto the hubs with your hands. If the wheel bearings are bad you should feel a roughness or vibration while spinning them. Since you described this as a thump I would say problem is not your wheels. They would make more of a clicking sound. Good Luck
Jan 27, 2009 | Cycling
Cycling Logo
119 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
