Question about Epson Office Equipment & Supplies
All lights are flashing I have turned off printer and restarted with no results
  • dwagner838 Sep 10, 2010
    It says there is a paper jam There isn't It says a ink cartridge is low NoIt says there is an incompatible memory card i don't have one It says the paper thickness is set on H I haven't changed it and i don't know howIt says the epson Stylus CXneeds a service
    President:
  • 1,566 Answers
Have you tried reinserting all the ink cartridges? Also, what is the model of this printer?
Posted on Sep 11, 2010
    Master:
  • 515 Answers
Did you check the manual and see what that means? I found some solution for Epson printers but I will need more detailed model number of your printer to post more specific solution if the following links do not bring a solution that fixes your issue.
http://www.fixyourownprinter.com/forums/inkjet/15598
http://forums.techguy.org/hardware/480537-epson-printer-lights-all-blinking.html
Posted on Sep 10, 2010
Printer paper stuck and red light flashing .how can i restart it?
You can't restart until the jammed paper has been removed. If the paper is out and none torn or still stuck in the printer try turning the printer off and then back on. That should reset it.
Oct 17, 2017 | Light Office Equipment & Supplies
Red Flashing lights
Hey,
Remove the cart ridges, restart printer, does the lights still flash? restart printer, place cartridges back in, make sure the tape is removed from the cartridge. also you can try cleaning the contacts.
So after you have connected the carts again, restart printer. how is it?
Thanks,
Ekse
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Error light and power light flashing together
What model? D110? 8110?
Try turning off the printer, clearing the print queue, restarting the computer, then turn the printer on.
If that doesn't work, what happens if you turn off the printer, disconnect it from the computer and then turn it on?
May 02, 2015 | HP PhotoSmart Office Equipment & Supplies
My Lexmark S405 power light flashes rapidly and will not come on.
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Lexmark Interpret S405 Wireless All-in-One...
All 3 lights are flashing. I have tried everything the manual asked me to do
You may need to restart the printer.
1. Press the power button to turn off the printer.
2. Press the power button to turn on the printer.
Proceed to step 3 if the lights are still flashing.
3. Press the power button to turn off the printer.
4. Disconnect the printer from the power supply.
5. Reconnect the printer to the power supply.
6. Press the power button to turn the printer
Aug 14, 2010 | HP DeskJet 940c InkJet Printer
Flashing orange light - restarted printer - still problem
My i560 printer will not print. The green light flashes once then the orange light flashes five times, this then continues all the time.
What can the problem be ?
ED.
Aug 23, 2009 | Canon BubbleJet i560 InkJet Printer
Lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
May 08, 2009 | HP DeskJet 5550 InkJet Printer
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
I have a HP deskjet 6949 series printer. I have had it for three months. My problem is that lights on the from panel(power button light, resume light and print cartridge status light) are blinking...
Power, Resume, and Print Cartridge Status lights are flashing in unison The printer might need to be restarted.
  1. Press the Power button to turn off the printer, and then press the Power button to restart the printer. Proceed to Step 2 if the lights continue to flash.
  2. Press the Power button to turn off the printer.
  3. Disconnect the printer power cord from the electrical outlet.
  4. Reconnect the printer power cord to the electrical outlet.
  5. Press the Power button to turn on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | HP Office Equipment & Supplies
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
