Question about Numark TTXUSB Turntable
I recently purchased two Numark TTXUSB turntables and an X6 Mixer. I am currently living in Cambodia where the voltage is 110/220. I plugged everything in and when I turned on the components, I immediately had an issue with the AC adapter on the mixer (mixer was the only thing not turned on). At that time, I switched the turntables to off and unplugged the surge protector. I contacted the store I bought the equipment from and they informed me the tables only use about 60v so there should not have been a problem but now, I cannot turn on either of the turntables. Upon searching this site, many suggestions were to check the fuses in the tables. I do not believe these models have fuses. Any help would be greatly appreciated.
  • 2 more comments
  • tonyaf6 Sep 10, 2010
    I tried a different outlet with no luck. The voltage is set to 110 and what frustrates me is I'm told Cambodia operates primarily on 110. I have other appliances plugged in and have had no problems. So do you think it is the transformer then?
  • tonyaf6 Sep 11, 2010
    I did try to plug it into the wall directly with a converter and even switched it to the 220 setting (which is now what I am told the preferred voltage. They really need to specify this when you ask since it does make a huge difference) but I had no luck. I assume the switch where the voltage can be changed is the transformer inside right? Is this an easy fix? Since I am in Cambodia, there are quite a bit of repair shops (Sony repair stores, etc) but I want to make sure it is an easy fix for them before they start taking things apart.
    I took the tables to the repair store (stores here can be sketchy so I was referred to the Sony store which had quite a few technicians) and though they had not worked on a turntable before, they were fairly confident they could fix the problem. To be continued. I will let you know if they fix the problem and if I have any other issues afterwards.
    Also, in response to the other individual who left a comment about the converters (and had a link), I was using one of those (which was the surge protector/converter) but the problem is, those only change the socket to fit your appliance, they do not change the voltage running through the equipment. Good thought though. Thanks for the input.
  • tonyaf6 Sep 18, 2010
    Everything works great now and the problem was the transformers. Easy and cheap fix. Thanks again midwest_tek for all of the correspondence
  • 864 Answers
Well firstly on the mixer and on the turntables there is a switch on the bottom that will allow you to switch the current. Secondly there is no fuse that i know of and i own a pair of these. Now firstly i would make sure its not just the outlet you have them plugged into. go in another room with the surge protector reset the surge prototector then plug the turntable in. Then let me know from there cause the transformer inside the turntables could have been blown out if the wrong voltage was set. But lets make sure that is not the case. Thanks, Midwest-tek
Posted on Sep 10, 2010
  • 2 more comments
  • Nathan Ayers
    Nathan Ayers Sep 11, 2010
    yes i do but that would be pretty bad cause i have had my house hit by lightning on several occasions and my turntables have never blown. An this might sound dumb. But you tried it without the power surge protector and plugged it right into the wall to make sure its not the power strip. If that continues the transformers could have blown. but would be weird that both would blow and the mixer. unless the power strip is blown or something. Lemme know from there and if that doesnt work i would replace the board inside that controls the transformer. It runs about 38.00 Usd for both.
  • Nathan Ayers
    ya you can take it to any electronic repair store and they should have no problem repairing it. And i actually opened mine up and there were 2 fuses inside. But i would take it to a repair store and worst comes to they can change the fuse but they can also test the transformer inside.
  • Nathan Ayers
    Nathan Ayers Sep 17, 2010
    i see that you were unhappy with the solution provided. If you still need help please let me know.
    I thought I commented back on this. I receive the tables back yesterday and the problem was the transformer inside the turntables. Everything is working now and only cost about $30 per table. Thanks again! Glad it was an easy fix (for such a stupid mistake)
  • 2,973 Answers
Voltage can not be 110/220.it has to be either. I only hope you have not burnt them with over voltage. Check the input voltage on all three. Then we willtalk.
Posted on Sep 12, 2010
  • 10,865 Answers
Hi. Generally, the electricity in cambodia is 220 volts AC, 50Hz.
Here is a link to the types of adapters needed if your turntable is from the states. http://www.international-electrical-supplies.com/cambodia-plug-adapters.html
Since you plugged in the turn tables and they are not working now, they need to be checked over. I believe you may have fried a wire in each with the higher voltage. J.
Posted on Sep 11, 2010
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
My numark x6 mixer does not work, it powers on, no output
Unless you can find someone local to fix it , you'll need to get something else
it's something internal broken and probably not an easy home fix
Nov 02, 2009 | Audio Players & Recorders
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
My power cord was pulled out while still on.
Are you talking about a Numark DXM mixer? If so, why would you say you have an issue with a CDJ-800? Numark Parts can be found here.
If not, you need to be more specific as to who makes your mixer.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 10, 2009 | Pioneer CDJ-800 Turntable
Hi, i have recently started djing and i am wondering if i have to run my speakers through an amp into my mixer or is there any kind of adapter i could get so i could just plug my speakers into my mixer....
Typically in about 95% of cases you will have to amplify your signal coming out of your mixer, befor going to your speakers. The line voltage that comes out is too weak to be heard unless amplified. When you purchase your amp, let the m know what the ohm rating is of your speakers,... this can be found on the back of the speaker, and will usually be 4 or 8 ohms(sometimes 2 or 16 but not too often).
Mar 04, 2009 | Numark TT1520 Turntable
I just assembled my numark ttxusb turntable but the stylus was not included
Go back to the dealer you bought the deck from. He is responsible for providing a stylus and fitting it for you.
Jan 18, 2009 | Numark ttUSB Turntable
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Numark TTXUSB Turntable Logo
165 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
