I have a mac OSX. Am trying to connect toEvo-W301AR OvisLink router but the instructions are for Windows and not mac. Everything plugged in and ok but cannot configure network card or validate myself. Any answers please?
sandeep239
  • 59 Answers
SOURCE: validating identity
it is just that the network key which is stored in the computer is not working so the 1st thing u need to do is verify the network key for that go to 192.168.0.1 from internet explorer enter the user id & password of ur dlink ( default id: admin password : admin) the go to wireless check the WEP or security key which is present their. reenter that key the computer & try to connect.
If it didn't work then go to control panel >> system >> hardware>> device manager
look for the network adepter & unintall the wireless network card
restart the computer
once restart it will automatically reintall the wireless card driver
then go to control panel>>Network Connection
right click on wireless network connection
select view wireless network connect
select ur network name & connect it will ask for the key provide the key & once u do that it will get connected & work fine
if in case u have the same problem replay back & i help u out with it & also provide all the details like which windows & network card etc
Posted on May 25, 2008
tech curly
  • 298 Answers
SOURCE: Setting up port forwarding: belkin wireless g plus mimo router
candice,
you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
Posted on Aug 01, 2008
watz up
  • 6 Answers
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Posted on Sep 11, 2008
HeLpINHaRrY
  • 210 Answers
SOURCE: Unable to connect to Linksys BEFW11S4 router from new Toshiba lap
this sounds like security problems , other people have experienced problems with vista but most have been able to resolve them.
whilst connected to your router using an ethernet cable open a browser windows and type in the rounter address these
are usually one of 2 most likely yours is
192.168.1.1
and typing password as "admin" and no user name. Use your password if you have changed it earlier 2
Go to wireless tab. 3. Go to wireless security sub-tab 4. If security mode is wpa or wpa2 note down passphrase/shared key, if security mode is WEP note down wep key number 1. This will be your network key
also check other.
On the Vista laptop with the connection
Start --> Network
Click on Network and Sharing Center
if It shows a red X between my network and the Internet.
click on the Customize link (below and right of the red X)
Under location type if it was set to Public. change it
to Private. Hit Next
At that point my whole network might go down,  and
reset the router. (turned off and turned on)
After that my red X under network and sharing center
was gone. And my internet connection problem was gone.
I forgot to mention that before you shoul have turned
off all software firewalls and virus scanners. prior.
if that does not work when you are logged into the router page 192.168.1.1 check to see if their is an option to update the router software/firmware ,if their is no option then you  may have to manually downlaod the firmware from linksys and update that way .
Hope this helps if not ask for clarification on anything your unsure of.
Posted on May 14, 2009
SOURCE: Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Posted on Mar 31, 2010
My iphone 5s cannot find my cannon mx452 printer
Please try the following steps to connect the unit to your Wi-Fi router:
1. Press the Setup button on the printer.
2. Use the arrow keys to select Drive Settings and press OK.
3. Select LAN Settings and press OK.
4. Choose Wireless LAN Setup and press OK.
5. If a WPS prompt appears, press the STOP button.
6. Select Standard Setup and press OK.
7. Select your Access Point and press OK. When entering the passphrase, use the Tone or Star (*) key to change character modes.
Once this has been done, insert the CD for the unit into your Windows or Mac OSX computer and perform the installation.
May 18, 2014 | Canon Pixma MX452
My apple OSX 10.5.8 Always says my computer is not on line. How do I get it on line
Is you computer connected to your route via an ethernet cable? If it is, check the port on the router to see if the connection light is glowing. Next, check you network settings and set the "Configure IP Address" to be "Using DHCP". This will also the router to allocate an IP address and settings to computer. Now see if you can access the internet.
Snow Leopard Support
Mac Basics Connecting your Mac to the Internet
Oct 11, 2012 | Apple Leopard 10.5 Osx Mac Operating...
USB to serial converter will not link to Macbook
the mac is still a mac but running windows, is sewing machine pc/mac compatible? if it is then boot under osx if u cant its not osx compatible only pc
Apr 24, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
How to configure 4 port router
If you just purchased and opened the box-
1- open your package and take out the instructions on what do to for setting up (not the manual)
2- connect your modem (source of internet) to the internet port of your router with the cable provided by your router packaging.
3- with the other available cable (that you already had) connect to one of the 4 ports (prefferably port #1) and the other end to your PC/Mac
4- If everything was powered on already during the connection of all these cables, you can to unplug the power to the internet modem (source of internet connection) and your router now.
5- Plug in the Internet Modem power to the wall and wait 30-45 seconds... then plug the power to the router and wait another 30 seconds.
6- now, try to go on the internet with your computer.
7- if it still doesn't work, just restart your computer 1 time
8- If it still doesn't work after you restarted your computer (very important to do this 1 time after following abpve steps), check the router's instructions for troubleshooting tips and follow up post us where you're stuck and provide to us:
What model router you're using, PC model and which Windows/Mac Operating system you're using. :)
Please rate us. :)
Jul 19, 2009 | Edimax 4 Port Wireless AP Broadband Router...
Need help installing my router
For mac computer there is not need to use the Cd assistance.
With the router connected to the router and modem, open the internet explorer. On the address field of your IE type 192.168.2.1.
- Click on Connection Type in the left hand column under Internet WAN heading. If asked to log in, live it blank and
- Select PPoE if you have a dsl connection. Enter your password and click Submit
-Select Dynamic, then click on Next,
- Select MAc adress in the left hand column .
- Click on Clon Mac Address then Aplly Changes.Wait 25 seconds.
-Close the windows.
-Unplg the cable from the green port for about 1 minute then plug it back in.
Now you should be able to connet to internet.
Oct 23, 2008 | Dynex DX-E401 Router
RE: NO ACCESS TO MICROSOFT SITES FROM ADSL/MODEM ROUTER OVISLINK EVO-DSL11
If your modem/router has a setup page, you may configure the MTU on it instead of configuring it on each computer. The modem/router's setup page can be accessed using the address 192.168.1.1 on the Internet Explorer's address bar or you may follow these steps.
1) Connect to the website integrated router by typing its IP address local (default: 192.168.1.1).
2) In the left menu, click on Show advanced Settings.
3) In section Hotel, please click WAN.
4) Please set the following parameters:
-- MRU = 1400
-- MTU = 1400
-- MSS = 1360
5) Click on Submit.
6) Click the Save Setting and Reboot and if necessary on Submit.
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
Dale
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Mac won't recognise network
Based upon the way you worded the message, you were trying to get the Mac working wirelessly? The description of how you were trying to set up your network (SysPref\Net\BuiltInEthernet) is for WIRED connections, not wireless. If you are running OSX and you have a built-in wireless adapter, use System Preferences\Network\Airport choice to set up for wireless connections. If you are trying to use the wire either because you don't have a wireless card or it is not working, check to make sure that the cable is good...maybe hijack the cable that you know works for your PC and test it. Please let me know if I am on the right track to solve the problem.
Jun 12, 2007 | D-Link AirPlus DI-524 Wireless Router
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Computers & Internet Logo
David Payne
David Payne
