Question about TruTech PLV16320 Television
We can turn the tv on and the picture comes on then disappears but we have audio
  • tabortots Sep 13, 2010
    sorry that I jumped ahead, will do and let you know, again I'm sorry
  • tabortots Sep 21, 2010
    I tried the flashlight thing and could not see anything. So what do you think?
    Champion:
  • 367 Answers
Are you still having problems with this?Please let me know.Thank You very much!
Tyler
Posted on Sep 12, 2010
  • 1 more comment
  • tabortots Sep 12, 2010
    you didn't answer the first question.
  • Tyler Bearor Sep 13, 2010
    I was going to tell you how to fix your TV,but I just wanted to find out if you were still having problems with it before I explained what to do.It sounds to me like you either have a bad inverter board(The board that lights up the screen),or a bad bulb in the screen itself.When you turn the TV on,and the picture goes away,shine a light on the screen,and see if you can see a picture.I hope this helps.Thank You very much!
    Tyler
  • Tyler Bearor Sep 23, 2010
    Is your TV a Trutech PLV16320?I would have to say that the inverter board (The board that lights up the screen) is bad.Have you taken the TV apart?If so,the inverter board is on the left hand side under the metal cage with all the pink,and white wires going to it.You might even have some bad capacitors in the power supply in the circuit that supplies power to the inverter.If you can take it apart,and send some pictures of the board with the power cord going to it,I can tell you which capacitors if any are bad.They have a rounded top to them instead of being flat.I hope this helps.Thank You very much!
    Tyler
Our receiver is connected to our cable box via an HDMI cable. Picture and audio show up fine, then goes out for a minute and then comes back--this keeps happening. Every time the picture/sound disappear,...
Connect the TV directly to cable box to make sure the TV and cable box are ok. If you have picture then the receiver is no good. Some Denons have problem with HDMI board (digital unit).
Oct 06, 2009 | Denon AVR-2308CI
Picture goes off within seconds once turned on
You will have to do some detective work here. If you are getting audio but no video then
the next time this happens take a strong flashlight and hold it against the LCD screen.
Look closely around the edge of the flashlight and see if you can see an image.
If you see an image then the problem will probably be in the inverter board or the power supply board to it.
Mar 06, 2009 | LG 42LG70 42 in. LCD HDTV
Vcr picture problem
clean the heads. check out my tip
Nov 02, 2008 | Orion VR213 VHS VCR
CRT Board
A crt board can cost from $25 to $40, the problem is that crt board should be tested before replacement, even if it is the most likely cause, there is always possibility that there is also something else (tube, main pcb etc.)
Jul 08, 2008 | Televison & Video
NO AUDIO OR AUDIO GOES IN AND OUT
problem is defective part on audio bd., either audio I.C. or a bad resistor or capacitor on the output side of the I.C.
Dec 30, 2007 | Sony KP-53V90 53" Rear Projection...
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
TruTech PLV16320 Television Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
