Hi, I want to wire a Type 19/T Thermomess thermostat to my oil boiler at home. I am not too sure what wire I should connect to the terminals. On TR (the temp control) I have points 1, 2, P1 and on STB (reset switch unit) I have 1, 2, and P1. My mains power goes to the burner via the thermostat and I want to connect the wires correctly. Does the mains cable connect to TR (Live on 1, with Neutral on 2)? Do I connect burner cable to STB (Live on 1 and Neutral on 2)? What is P1 ? do I need to jumper across these 2 points on TR and STB? Need help?
4 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Thermostat wiring
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Posted on Jun 02, 2009
  • 30 Answers
SOURCE: need to connect 240 volt 60 amp breaker with 6.3 - 4 wire
Yes the red and black wires are both hot. As for the white and bare wire, they can both go on the neutral bus bar because ground and neutral are not separated. Actually you don't have to have the bare ground wire, but it is a good idea to connect it for inspection and code purposes. If you don't have a neutral bar in the subpanel, you can just connect the white and bare wires directly to the box and they will be ok.
Posted on Aug 13, 2009
  • 77 Answers
SOURCE: HELP!! New install of GMUH75-E3A
You need to find out if the problem is in the T-stat, T-stat wire or in the furnace you can do this in a few easy steps
Step 1- Unwire the low voltage from the furnace. Then turn the power back on and see if the blower comes on if it does then the problem is in the furnace and you will need to troubleshoot the furnace (see bottom of page for troubleshooting furnace) if it does not then proceed to step 2
Step 2- Wire the low voltage back up to the furnace (follow the wiring diagram below). And unwire the T-stat, make sure that no wires are touching each other, then turn the power back on to the furnace, if the blower starts then you have a short in the T-stat wire and you will need to pull a new wire. If it does not then proceed to step 3
Step 3- Turn the power back off at the furnace and wire the T-stat back up (follow the wiring diagram below). Turn the T-stat to auto heat 90 if the heat does not start but the blower just runs then you need to replace the T-stat.
http://www.hvac-for-beginners.com/furnace-troubleshooting.html
wiring diagram
Posted on Nov 24, 2010
Wiring diagrams forthermostat from boiler
Does the Thermostat say it can control and A/C also? The blue wire is for Air Conditioner and does not connect to the boiler.
Aug 17, 2014 | Heating & Cooling
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
My central heating is set to max 20 degrees but we keep coming home to find house hotter than that. The thermostat is in the hallway, the boiler and froststat (latter newly replaced) are in the integral...
Hi Lyn,
Had the same problem with my system. turned out to be the thermostat in the hallway. Mine is an older electro-mechanical type with contacts that open and close as the temperature changes. (these type of thermostats click as you rotate the temperature dial) What had happened was the contacts had stuck closed even as the temperature rose and thus the boiler kept going. I cleaned the contacts with WD40 oil and everything is fine again. If you have the same type of thermostat this may be the problem. Be aware that if you or anyone else removes the cover of these thermostats there is live mains at the faulty contacts, be sure to switch off the circuit feeding this thermostat or remove/switch off the fuse in the main fuse box. Alternately you could replace the thermostat. If you have an electronic digital thermostat then this solution is not valid.
Good luck
Nov 24, 2013 | Heating & Cooling
Operating worcester bosch 240 gas boiler
Control systems operate on a much lower voltage than the boiler. You should be able to put any kind of thermostat in for it. Just be sure of the wiring when doing it. If its a line voltage stat, I'll need more information to advise correctly.
Nov 15, 2013 | Heating & Cooling
I do not have a room thermostat connected to my oil fired central heating boiler. I want to install a wireless room thermostat to avoid having to run cable. how do i go about this and which is the best...
All wireless wall thermostats are Millivolt controlled. rather than having an 18 or 24 volt (transformer) wired wall thermostat. Before purchasing any wireless wall thermostat, you need to determine what your oil fired boiler requires for activation. My experience tells me, that it's going to require either 18 or 24 volts. In which case a wireless thermostat won't work.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Heating & Cooling
Hi, I have an X1 francis espresso machine. I am having a problem with the machine heating up the water. I am not sure if it is the element, or the thermostat. The temperature guage does not rise above...
The thermostat is a bit that goes into a hole on the boiler, connected by a wire to the gauge. It is most likely that the thermostat has come unstuck from the boiler and is registering incorrectly.
Sep 06, 2010 | FrancisFrancis! X1 Espresso Machine
Saeco Incanto Classic has no sign of life. Has horseshoe type heater, fuse has continuity. Power switch tests ok. May have experienced power outage.
Hi
There are 2 boilers in your machine. There is a main boiler on the left rear of the machine. It should have 2 thermostats that each have a reset button. The buttons are between the 2 wires on each thermostat. They are on the outside of the boiler between the boiler and the outside of the machine. Push the buttons and then try again.
Oct 23, 2009 | Saeco Incanto Classic Espresso Machine
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,375 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
