Question about Canon PIXMA MX310 All-In-One Printer
Turn on machine and the check printer comes up on screen and the number 5100, also the on/off light and alarm light blink back and forth.
    President:
  • 1,961 Answers
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
Posted on Sep 10, 2010
I cannot turn on the printer. The green light blinks; the alarm light blinks. "CHECK PRINTER" appears on the LCD with 5100 in the lower right corner. I checked all the connections; turned...
According to the Canon troubleshooting website here are the steps to follow for the PIXMA MX310 and Error Code 5100:
-Remove the cartridges
-Inspect the cartridges to ensure all packaging is removed
-Reinstall the cartridges
-Press the ON/OFF button for 2 seconds
-Unplug the printer and wait 10 seconds
-Check the printer for any obstructions including packaging materials
-Remove the scanner cover
-Open the lid - check for paper that is stuck; these can be very small pieces, so look carefully
-Plug the printer back in and power it on.
If that does not solve the problem you will have to contact a service repair centre. Good luck.. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a dell 5100 laptop. This morning i removed a program through add/remove programs. The computer need to be restarted. During the restart I left and came back the power light was blinking so I pressed...
Our expert technicians provide you dell tech support for desktop, computer, laptop, printer, drivers, etc. Call at our number 1 (800) 204-4427 and get 24X7 quality services.
May 19, 2017 | Dell Inspiron 5100 Notebook
How do i clear an error 5100 from my canon pixma mp250?
Try this technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 14, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
CHECK PRINTER (5800)
Please un and re install the device drivers following link
Installing Devices on PCs and Laptops
May 05, 2010 | Canon PIXMA MX310 All-In-One Printer
My cannon mx300 is giving me an alarm code 5100
5100 means either the carriage is not moving freely back and forth or there is grease or ink on the encoder strip. You can clean that clear plastic strip behind the carriage with a Q-tip, but also check on the right and left side for paper scraps stopping the carriage.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Error 5100 in Canon MP160
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer not working
On this printer, the alarm and data lights mean that the toner cartridge is empty. When you replace the toner, be sure to slide the corona wire cleaner across and back. This is the small light blue plastic piece on top of the drum cartridge. You'll see a small arrow in the plastic. Just slide it back and forth once or twice each time you replace the toner cartridge.
May 11, 2008 | Brother HL 1440 Laser Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
427 people viewed this question
old marine
old marine
