Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
It reads fan and the heater wont start up when you turn it on..
    Top Expert:
  • Raypak Master
  • 8,502 Answers
See if ignitor is lighting if so check gas
Posted on May 25, 2016
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
2005 impala heater fan runs constantly
read this post on what's causing blower motor to run all the time.
http://ricksfreeautorepairadvice.com/blower-motor-wont-shut-off/
Blower motor wont shut off Ricks Free Auto Repair Advice
Sep 14, 2017 | 2005 Chevrolet Impala
2002 gmc 1500 sierra starter clicks but wont turn over. Have checked fuses, charged battery, tried jump starting all it does is you can here solinoid click but starter wont turn. I did turn heater fan on...
Replace the starter, the solenoid cant engage the starter because it is locked up, hence the extreme voltage drop with the fan when you try to start it with the fan on.
Oct 04, 2011 | 2002 GMC Sierra 1500HD
How come heater fan wont blow
there are a few things that will cause this problem.
1. it could be the heater fan fuse
2. could be the heater fan motor itself
3, a bad switch or relay
check the fuse and then check for voltage at the heater motor itself, if you have voltage at the heater motor,, give the heater motor box a love tap with your hand and see if it starts to turn, if it does not turn or even if it does ( after tapping it ) - it is time to replace the heater motor.
c...
Jan 04, 2011 | 2000 Jeep Grand Cherokee
I CANT GET MY HEATER TO TURN ON. I HEAR THE THERMISTAT CLICK BUT HEATER WONT TURN ON. I THINK IT MIGHT BE THE PROGRAMING PART. I HAVE RESET IT ALSO
wer
ewr
Sorry to read about your heater problem.
Goto your furnace, have somebody turn on the heat.
see what kinds of noise your furnace makes. clicks, fans, etc.
If hear nothing, you may have a general control failure.
Also at the thermostat, you should hear a click, if you don't you may need batteries or the stat is defective.
Now I tried to help you. Please help me and vote/rate mt response. Thanks and good luck.
Dec 24, 2010 | Hunter Fan Company 5/1/1 Programmable...
Electric fan motor sometimes wont start. It tries
Your unit is a year old and sits around most of the year. Disassemble the unit to get to the fan motor. When you can see the bushings on both ends of the motor shaft use a light oil such as 3-in-one to lubricate the bushings. Rotate the fan blades for a while. Relubricate. Continue until the motor turns freely. Clean up any oil spills. This should solve your problem if you haven't damaged the motor by trying to run it with dry bushings. The lubrication should be done at the end of each season and at the begining before the unit is put in service. Let me know if I can be of anymore help.
hardrocko
Thanks for using FixYa
Feb 25, 2010 | Heating & Cooling
Heater wont start makes buzzing sound
Thanks for your question,
Changing the brushes might help, but more often since you said its really stiff, something in the motor over heated and it would probably benefit you more to change out the motor, the windings could be burned up, at least you will have the peace of mind that you know your motor wont lock up again. if it were me, I would replace over repair, hope this helps, please rate this and let us know what happens, thanks again,
mr.grzz
Jan 26, 2009 | Master Heaters Master B115DT 115,000BTU...
1990 olds 98 blower motor wont shut off stay on when key is turn off
I would start at the fuse. Does the blower motor turn off when the fuse is pulled? A relay is usually used in this circuit and can sometimes "stick" allowing the blower motor to receive constant power. A quick check to see if it is a wiring problem, switch or the relay its self would be to find the blower fan relay and see if there is another one of the value you can swap with it. If the problem goes away, chances are it is the relay but I always like to take a volt/ amp reading to double check my work.
Dan
Sep 04, 2008 | Oldsmobile Regency Cars & Trucks
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
63 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
