Hs-dvr042 - Computers & Internet
Serial Number Problam..15H................
Try the below serials may it work for you
HS-2993WD-HSC5DD-9GQCF6
OR
HS-FC9VKC-GBS74E-7LVYS6
OR
HS-667YKK-HYDF6P-GTMR8G
OR
HS-HMJRNE-LM32K7-MFEZDV
OR
HS-1NX2H-BRQFK-B34GP-JYE1G
OR
HS-EE41XW-L9DPSX-TPZ73B-3ZERYZ7
Sep 10, 2011 | Sony Sound Forge 8.0 for PC
Looking to obtain a HS-U448 manual and remote.
The manual is available from the Mitsubishi Support site: http://support.mitsubishi-tv.com/documents/HS-U448 . The direct link to the manual is http://support.mitsubishi-tv.com/files/oguide/HS-U448.pdf .
The original remote is no longer available. However, remotes.com has a substitute remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HS-U448&uuid=13065385902780 .
A number of universal remotes will probably also work. The codes will be in any remote that still controls a VCR if the remote was programmed after the HS-U448 was released.
I hope this helps.
May 27, 2011 | Mitsubishi HS-U448 VCR
Serial number sound forge 8.0
I Need Sound Forge 8.0 Serial Number
Jan 24, 2011 | Sony Sound Forge 8.0 for PC
I cannot get my Vtech LS6204 to register. I have tried everything and the screen always reads registration failed.
I have a 2-handset VTech CS6419 that I had been using w/o problems for months. Both HS were always plugged in and charged. One day I found the base HS would not ring and the screen had the message that I needed to register the HS. Pressing the "find HS" button to start the process only made the accessory HS, not the malfunctioning base one, ring. I solved the problem by 1) unplugging the base, 2) pulling the batteries from BOTH handsets, then 3) replugging in the base and reattaching the battery for ONLY the malfunctioning HS. 4) I then did the registration process again (press the "Find HS" button on the base for 4 seconds, then press the # button on the HS and wait.) The malfunctioning HS then registered! I then reattached the battery to the accessory HS and returned it to its' base. Problem solved!
Jan 01, 2011 | Vtech LS6204 1.9 GHz 1-Line Cordless...
I need sony soundforge 8.0 serial number
HS-F373CJ-6X2C6X-9WRWGB
HS-93BRCE-QWPLGB-S2KBZD
HS-5LK8J5-HN6XEG-0L39ML
HS-5TMF21-2YZ3ZV-Q0SGV5
HS-9S1NHQ-S0R7GZ-H15P7E
HS-GJPK2Y-G76519-GY0425
HS-C0W6SR-8Z80SZ-44D2W6
I hope this will help you ( alien 1)
Dec 12, 2010 | Sony Sound Forge 8.0 for PC
Want serial number for sony sound forge 8.0
hi friend use any one of the below code
HS-8HLYXX-PTYBPQ-RJNRTQ , HS-5GLG73-SCMXW8-5589GD , HS-7C9KS4-60PG31-TJ9ER0 , HS-59246M-QL1CSK-V8DN14 , HS-27GMZR-ES1CC9-7WPQHH
Mar 30, 2010 | Sony Sound Forge 8.0 for PC
Sony sound Forge trial version asks for serial number
try one of these serials
or HS-5GLG73-SCMXW8-5589GD
or
or HS-59246M-QL1CSK-V8DN14
or
or HS-8HLYXX-PTYBPQ-RJNRTQ
or
or
or
or
Jul 26, 2009 | Sony Sound Forge 8.0 for PC
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
